- Hardware & Machines
- Computers and Hardware
- LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
- meister
- Thank you received: 502
18 May 2023 08:30 - 12 Aug 2024 08:29 #271608
by meister
LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5) was created by meister
LinuxCNC-RIO is a code generator for using FPGA boards as Realtime-IO for LinuxCNC.
Furthermore, the complete configuration and hal is generated.
a json configuration file serves as the basis
github.com/multigcs/riocore
youtube.com/shorts/G5V5OM_ORsk?feature=share
- no Soft-Core / logic only
- no jitter
- fast and small
- communication via SPI (with Raspberry PI 4) or Ethernet
- generated verilog-code / setup via json files (free pin-selection)
- using free FPGA-Toolchain or commercial (depends on the FPGA)
- runs on many FPGA's (like ICE40, ECP5, MAX10, Artix7, Gowin, CycloneIV, ...)
- supports Open and Closed-Loop
- multiple and mixed joint types (like Stepper, DC-Servo, RC-Servo)
Last edit: 12 Aug 2024 08:29 by meister. Reason: updated info
The following user(s) said Thank You: kostas, tommylight, Clive S, itai, aparecido, besriworld, MaxEkb77, cakeslob, Aciera, rounyworks and 6 other people also said thanks.
- meister
20 May 2023 08:54 #271745
by meister
Replied by meister on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
new demo video
The following user(s) said Thank You: tommylight, 0x2102, rounyworks
- meister
24 May 2023 13:47 #272095
by meister
No comments ? really ?
Features-List:
* Digital Input
* Digital Output
* Expansion to add I/O's via shiftregister's
* PWM Joint Output with DIR-Pin
* RCSERVO Joint Output
* Stepper Joint Output with STEP/DIR/ENABLE(optional) pins
* Variable-Input for frequency measurement
* Variable-Input for pulse counting with up to 3 pins (all optional)
* Variable-Input for pulse width measurement
* Variable-Input for Quad-Encoder (int32_t)
* Variable-Input for distance measurement via ultrasonic sonar sensor (HC-SR04)
* Variable-Output for frequencys
* Variable-Output for PWM-Signals with optional DIR pin
* Variable-Output for RC-Servos
* Variable-Output for Sine-Waves via PWM-Signal (multi. phase)
* Variable-Output using digital poti with UpDown/Incr. Interface (like X9C104)
no mesa alternativ (yet) but close
Features-List:
* Digital Input
* Digital Output
The following user(s) said Thank You: MikkelRS
- spumco
- Thank you received: 905
24 May 2023 15:24 #272106
by spumco
You guys who are working on the cutting-edge alternative micro controllers are doing some really nice work. I think - I'm not in a position to evaluate.
But there is, I suspect, a not-insignificant population of LCNC users who have no clue about the microcontroller world, or coding computers, or other non-machining topics. Python is a mystery, as is C or other machine programming.
I'm one of them.
I'm able to digest about 5-10% of the forum threads discussing the Remora, OPi5, and similar edge-case ports of LCNC to non-Mesa microcontrollers. But most of the time I'm watching from the sidelines, fatally confused, and simply waiting for one of you big-brains to declare:
"It does the following, it costs this much and here's where to buy it, and here's the idiot-proof instructions on how to use it without the standard horrible Linux-hardware insanity"
When you throw that one out there, you'll get more comments from a broader segment of the LCNC community.
Replied by spumco on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
I'm one of them.
The following user(s) said Thank You: meister, timo
- Thank you received: 7504
24 May 2023 15:41 #272110
Great job, thank you.
Replied by tommylight on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
I did use the "thank you" button as i was (and still am) pressed for time, a bit more than usual.No comments ? really ?
- meister
24 May 2023 17:07 #272119
by meister
ok, that's what i wanted to hear,
I'm trying to put my focus on the hardware and build a usable board.
And try to write the documentation for users, not for developers.
thank you !
thank you !
The following user(s) said Thank You: phillc54, tommylight, Clive S, 0x2102, besriworld, spumco
- drewnabobber
- Thank you received: 27
24 May 2023 18:53 - 24 May 2023 18:55 #272123
by drewnabobber
Replied by drewnabobber on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Replying to spumco:
Really don't want to clutter up this thread with a digression as meister's project is some really fantastic work, but this is exactly what the RPI4 image for Remora and FlexiHAL is addressing.
Last edit: 24 May 2023 18:55 by drewnabobber.
The following user(s) said Thank You: meister, cakeslob, spumco
- drewnabobber
24 May 2023 18:58 #272124
by drewnabobber
While I am sure you have your own ideas for hardware design, you may find the FlexiHAL an interesting starting point, the design is open and everything is posted. It would not be hard to adapt it to the ICE40 instead of STM32.
- spumco
24 May 2023 20:11 #272127
by spumco
Genuinely appreciate all the efforts to make LCNC more accessible to us Luddites.
No, thank you. And all the other hardware/software gurus here, too.And try to write the documentation for users, not for developers.
- pippin88
- Thank you received: 51
25 May 2023 01:05 #272139
by pippin88
Replied by pippin88 on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Nice work. I'm very happy to see more options.
I have some Mesa boards and they are great, but cost of postage from US is a killer.
Not being that Linux savvy, I haven't yet tried an ARM board (RPI4/Orange Pi). These boards have SPI / i2c / feasible ways of interfacing between LinuxCNC and a hardware realtime board.
To me there is still a gap in realtime options for use with x86/standard PCs.
These days ethernet is the only consistent feasible port option, and currently that means Mesa or Pico only I believe.
Time to create page: 0.376 seconds
