- Thank you received: 14
Doubt this will be reliable, Tommy. Sure, prolly be spinning a motor on the benchtop and comm for 10~20min but most likely be failing more often than not. E.g. zero timing critical pthread/mutex//locks/semaphores/gives/takes nothing at all. Could get away without it in a parallel compute domain but in this case, it's all serialized runtime (locks/integrity mandatory).Had the same issue, so it was easier to resolder the pins, but still did not work.
Had no time to test anymore, it is sitting on my desk here for quite some time, but i think i might give it a go these days.
