ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
1 year 11 months ago #315651 by Mecanix
RMT will have to wait, limited time, but lately i am stuck at home/shops so maybe...
Nah, not my channel, got none of that online exposure, maybe one day but I doubt that. Same reason as yours, so little time for those sort of things :(
All the best to you & family. And be safe in that shop!!
1 year 11 months ago #315659 by tommylight
Yeah, it is probably Meister's channel, sorry for the mix up.
...got none of that online exposure, maybe one day but I doubt that. Same reason as yours, so little time for those sort of things :(
I just had two friends in the shop, fixing 3 PC's, all the time they were screaming at me for not recording that and putting it online as they would like to watch that again and again! I am a pedantic p.o.s when i work with PC, so i always think that would be boring as hell ! :)
Thank you very much. Been quite some time since i injured myself... aaah good times :)
The following user(s) said Thank You: Mecanix
1 year 10 months ago - 1 year 10 months ago #316374 by michaeln
Does the spiethconfig work for anybody?
I tested a lot, but i don't find the problem.
I insert printf commands in the code and get strange outputs. I change from picocom to putty, the same.
The command in short and long version:
spiethconfig -s 19 -i 23 -c 18 -e 0 -t 4
spiethconfig --miso 19 --mosi 23 --sck 18 --csenable 0 --interrupt 4
The output:
Invalid or missing Chip Select pin (0>128)
Command returned non-zero error code: 0x1 (ERROR)
I insert some printf-commands ( bold my changes):
            printf("argc: %d\r\n", argc);
            if (result.count("s")) { miso_pin = result["s"].as<int>;(); }
            printf("MISO pin: %d \r\n", miso_pin);
            if (miso_pin < 0 || miso_pin > 128 ) { printf_P(PSTR("Invalid or missing MISO pin (0>128)\n")); return EXIT_FAILURE;}
            if (result.count("i")) { mosi_pin = result["i"].as<int>;(); }
            printf("MOSI pin: %d \r\n", mosi_pin);
            if (mosi_pin < 0 || mosi_pin > 128 ) { printf_P(PSTR("Invalid or missing MOSI pin (0>128)\n")); return EXIT_FAILURE;}
            if (result.count("c")) { sck_pin = result["c"].as<int>;(); }
            printf("SCK pin: %d \r\n", sck_pin);
            if (sck_pin < 0 || sck_pin > 128 ) { printf_P(PSTR("Invalid or missing SCK pin (0>128)\n")); return EXIT_FAILURE;}
            if (result.count("e")) { cs_pin = result["e"].as<int>;(); }
            printf("CS pin: %d \r\n", cs_pin);
            if (cs_pin < 0 || cs_pin > 128 ) { printf_P(PSTR("Invalid or missing Chip Select pin (0>128)\n")); return EXIT_FAILURE;}
            if (result.count("t")) { int_pin = result["t"].as<int>;(); }
            printf("INT pin: %d \r\n", int_pin);
            if (int_pin < 0 || int_pin > 128 ) { printf_P(PSTR("Invalid or missing Interrupt pin (0>128)\n")); return EXIT_FAILURE;}
and get the result:
argc: 7
MISO pin: 19
MOSI pin: 23
SCK pin: 18
CS pin: 255
After that i change the sequence of the variables, the problems stay at the forth position. i saw that the out from argc stay at maximum 7 (in my opinion it should be 11).
Does it work for anybody?
If yes, what does is made wrong?
Thanks and best regards
michaeln
Hello,
now i found the problem of the SPIConfig.
Here is the code with my changes, forked from sybexx with his changes:
github.com/michaelnu/ESP32_LinuxCNC_MotionController_RealTime
Best regards
Michael
Last edit: 1 year 10 months ago by michaeln.
1 year 10 months ago #316388 by tommylight
If i get a chance i will have a run at it tonight, still have all that mess on my table.
Thank you.
1 year 10 months ago #316441 by tommylight
Gave it a try, still reboots when enabling LinuxCNC.
Have to try another module just in case.
1 year 10 months ago - 1 year 10 months ago #316704 by aparecido
Has this error message appeared for anyone?
If so, how did you resolve it?
Can you tell me why it appeared?
Last edit: 1 year 10 months ago by aparecido.
Time to create page: 0.459 seconds
