ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
1 year 9 months ago #320103 by beauxnez
thanks same error message with the modification
1 year 9 months ago - 1 year 9 months ago #320135 by michaeln
Hello beauxnez,
on a fresh install from Linuxcnc from the ISO 2.9.4 it works with the two changes (ETH.h and puType::up;)
I think your problem is your system.
On which system do you work? Have you cleaned platformio/vscode?
Last edit: 1 year 9 months ago by michaeln.
1 year 9 months ago #320156 by beauxnez
I work on Windows 11 with Visual Studio Code, I haven't cleaned it, I don't even know how to do it.
1 year 9 months ago #320176 by michaeln
For me it works under a fresh installation from VisualStudioCode with the extension PlatformIO and GIT under Windows, too.
Ther are in the folder c:\Users\Your-User\ the folders .vscode and .platformio and C:\Users\Your-User\AppData\Roaming\Code . I think if you delete all it's like a fresh installation.
1 year 9 months ago #320263 by beauxnez
it works on another computer without modifying anything I have an esp32 wroom with an spi card do I have to change the card number here?
and by what number?
1 year 9 months ago #320311 by beauxnez
ok,
 I just found on the subject the config page on the github github.com/SybexX/ESP32_LinuxCNC_MotionC...in/SerialCommands.md ,
 I don't understand where you have to type the commands to configure the card?
Time to create page: 0.071 seconds
