ESP32/S2/S3 LinuxCNC Controller (6 axis hardware step gen), USB plug-and-play
1 year 9 months ago #320319 by michaeln
you can use the serial commands with a terminal like picocom.
try picocom -b 115200 /dev/ttyUSB0
But the spiethconfig does not work. Use the default settings
1 year 9 months ago #320337 by beauxnez
I succeeded, I am at the part "sudo halcompile --install esp32udp.comp" what should I do?
  it's not very clear for a novice
1 year 9 months ago #320367 by tommylight
Set the networking as described in the readme, connect stuff, open the included config folder, right click on the ini file and choose "open with" then linuxcnc.
1 year 8 months ago - 1 year 8 months ago #320396 by beauxnez
thank you,
 I modified the network settings, I think I am connected, I cannot open the .ini file with linuxcnc because I do not have the option,
 the 2 hal and ini files must be copied into a configuration created by stepconf wizard?
 if I copy them in I switch to qtdragon?
Last edit: 1 year 8 months ago by beauxnez.
1 year 8 months ago #320884 by mtyax
First and foremost, this thread is awesome; I can't wait to get in here.
Is there any real documentation on how to implement it? Maybe I'm just not finding it, so if someone could point me in the direction, that would be great.
Thanks all!
Keep up the great work!
1 year 8 months ago #322351 by OnkelKai77
Hello!
I'm new here and registered here because of this topic. Is it possible to get the firmware for an ESP32-S3? Or do I have to change something so that I can flash the ESP32-S3? I still have two of the S3 here and would like to test them as CNC controllers.
Thank you very much
Kai
Time to create page: 0.232 seconds
