Can I use Raspberry Pi 5 for Linuxcnc + ESP32 + W5500 for generating step pulses
04 Jul 2024 08:38 #304358 by yathish
Hi Linuxcnc community,
I have installed OS in raspberry 5 and Instead of using IO expander I want to use individual ESP32+W5500 for every motor and generate step pulses. If this is possible please help me with the steps in achiving it.
Refer the image below and get what I want to achieve
https://drive.google.com/file/d/1JCuLksqd7dcpAcJ44GajRwzOFmay_xuQ/view?usp=sharing
Thankyou
04 Jul 2024 08:50 - 04 Jul 2024 09:05 #304359 by meister
in principle, yes,
but you would have to build the hal component in such a way that the ethernet packets are sent and received in parallel,
otherwise it takes too long.
EDIT:
but since udp is used, this can lead to collisions.
maybe send with minimal delay and then wait for the responses
Last edit: 04 Jul 2024 09:05 by meister.
04 Jul 2024 09:28 #304362 by tommylight
Using ethernet hub or switch will add a lot to network latency, so it might not work at all, even if everything else works.
Never tried with a hub, but i do have a switch that works with Mesa boards for days without issues.
Still, i never use a switch on production machines, the risk is to big.
Network hub = old, any packet sent to any pc wired to it will be sent to all connected PC's.
Network switch = new, any packet sent will be sent only to the PC with the IP address contained in that packet.
04 Jul 2024 09:33 #304363 by yathish
Can you tell me how to configure HAl and ESP32 if I have to build it for just 1 axis?
  • Platinum Member
  • Platinum Member
04 Jul 2024 09:38 #304365 by Cant do this anymore bye all
No don't use a hub.
Linuxcnc-rio is awesome, with a single WT32-ETH0 and a direct cable connection and inexpensive FPGA you can do 4 axis easily and way more.
04 Jul 2024 09:39 #304366 by yathish
Hi @tommylight, thankyou for your insight.
Now i want to expand my inputs and outputs in raspberry pi 5, can you suggest me how to expand my i/o and if there is any solution can you also tell me how to configure HAl
04 Jul 2024 09:42 #304367 by tommylight
Sorry but i do not use RPI's at all,and that will not change untill their price drops back to under 50$.
04 Jul 2024 09:48 #304368 by meister
No don't use a hub.
i think he will use ethernet for wiring like with ethercat.
04 Jul 2024 09:59 #304370 by meister
Sorry, why not ? i like the RPI's, especially via SPI
  • Platinum Member
  • Platinum Member
04 Jul 2024 10:05 #304371 by Cant do this anymore bye all
Refer to this post forum.linuxcnc.org/18-computer/53136-can...g-step-pulses#304365
Time to create page: 0.131 seconds
