Pc reboot / 5i25(6i25) & 7i77
17 Aug 2024 01:22 #307984 by Benb
Replied by Benb on topic Pc reboot / 5i25(6i25) & 7i77
My understanding is that your computer reboots only when you run Linuxcnc?
You could install the latest Linuxcnc and test your lathe  with your current setup files (ini, hal, ui …)
19 Aug 2024 12:32 #308132 by Sami
Replied by Sami on topic Pc reboot / 5i25(6i25) & 7i77
-Check if the ram memory is detected correct in the bios.
-Replace ram memory, check cpu temperature (old thermal paste?)
-Another/Newer kernel
-maybe it's just a defect in the mb or cpu
Ram is detected ok in the bios and we had three different mb where reboot issue
is present, when zen 3 Ryzen prosessor is installed (Ryzen 5 5600G or Ryzen 7 5700X).
We have been also tested with latest release of linuxcnc (2.9.2 and 2.9.3) with
rt-kernel and realtime kernel (5.4.258).
Remove the lathe power plug, try again.
We have started linuxcnc without lathe hw plugged in and it start until error of
missing I/O-information about door etc. When lathe hw is connected to 6i25 pc reboot
at line addf hm2_5i25.0.read servo-thread.
When we comment that line out, we can start linuxcnc, but all is not working ok
(we can see I/O information etc, but could not start machining).
We have tested latest versions and still have reboot issue with zen 3 prosessor. Latest versions
works ok with older pc hw and we can machining with setup from old pc (ini, hal etc.).
We also tested old hdd (old linuxcnc and ubuntu) with new pc hw (zen 3) and have this same reboot
issue with it. Old hdd with old linuxcnc&ubuntu works ok when Ryzen 5 1600 or older cpu is in use.
Otherwise all tested pc works ok and those tested pc's have been used several months in other use
without issues.
19 Aug 2024 12:43 #308134 by tommylight
Replied by tommylight on topic Pc reboot / 5i25(6i25) & 7i77
That points to a bad wiring issue with outputs or inputs, or power issues, or different potential between Mesa/lathe electronic/drives/spindle drive.
Remove all the input and output plugs from the Mesa 7i77, power on everything and start LinuxCNC.
If that works, power off the machine, plug one of the connectors, turn on the machine, test connectors one by one.
When you find a connector that causes issues, start removing wires from it and test.
Do not remove wires or plugs while the machine is on.
19 Aug 2024 14:04 #308138 by royka
Replied by royka on topic Pc reboot / 5i25(6i25) & 7i77
Kernel 5.4 is not that new, there have been some issues with Ryzen CPUs. So if Tommylight's solution doesn't work you could try this rt kernel 6.10
drive.google.com/drive/folders/1L28lG0zD...2XQJx?usp=drive_link
Time to create page: 0.208 seconds
