Using skr 1.4 turbo with w5500 for Linuxcnc
- 3dtech_ks
- Thank you received: 5
14 Oct 2024 11:48 #312052
by 3dtech_ks
Using skr 1.4 turbo with w5500 for Linuxcnc was created by 3dtech_ks
Hello , can someone please share the config file for skr 1.4 turbo with w5500 module for linux cnc use
- Thank you received: 7488
14 Oct 2024 14:15 #312060
- 3dtech_ks
14 Oct 2024 15:48 - 14 Oct 2024 15:48 #312070
by 3dtech_ks
Replied by 3dtech_ks on topic Using skr 1.4 turbo with w5500 for Linuxcnc
Im not sure yet, i know skr 1.4 uses LPC1768 , SKR 1.4 TURBO uses LPC1769 , but can i use the same config.txt for both ?
Last edit: 14 Oct 2024 15:48 by 3dtech_ks.
14 Oct 2024 16:54 #312075
Replied by tommylight on topic Using skr 1.4 turbo with w5500 for Linuxcnc
The only difference between LPC1768 and LPC1769 is the working frequency, so everything should work for both, see last post on the link.
community.nxp.com/t5/LPCXpresso-IDE/LPC1...ferences/td-p/578600
09 Nov 2024 16:07 - 01 Apr 2025 20:37 #314127
Now we have control of TMC drives through UART, apparently:
forum.linuxcnc.org/show-your-stuff/50177...ny-solder-bot#314119
Last edit: 01 Apr 2025 20:37 by tommylight. Reason: more info
