Building new plasma table
- tcbmetalworks
- Thank you received: 21
24 Oct 2024 05:23 #313032
by tcbmetalworks
Building new plasma table was created by tcbmetalworks
Hello, I built a mach 3 based plasma table using junk china parts. I am sick of dealing with problem after problem. Latest one is the board crashing and losing all usb including the mouse and keyboard. I figure it's time to upgrade and the thc integration really captivated me towards Linux cnc aswell as the freedom modify. I have never ran linux before but I am no beginner to computers and building stuff. I was looking into the mesa boards. Does anybody have any recommendations for a super reliable computer to purchase to run linux cnc in a industrial setting and any recommendations for the breakout board and thc to run a plasma table? Thanks.
- Thank you received: 7488
24 Oct 2024 11:49 #313059
Replied by tommylight on topic Building new plasma table
Reliable computer will not help you, any computer will do.
The thing with plasma is they create huge amounts of interference when striking and arc, so grounding and proper shielding are mandatory.
Normally you can get away with Mesa 7i96S and THCAD, and they are extremely reliable.
Here are some ideas:
forum.linuxcnc.org/show-your-stuff/38547...plasma-build?start=0
- tcbmetalworks
24 Oct 2024 14:57 #313093
by tcbmetalworks
Replied by tcbmetalworks on topic Building new plasma table
I understand that any computer will do but with my previous set up I've ran into issues with the actual computer being unstable. Halfway threw cutting the thing crashes complete freeze up. I am looking for a computer that is able to handle being left on for days on end no instability.
24 Oct 2024 16:54 #313109
It can also be failing power supply or memory modules or overheating processor.
Dell Optiplex 980 big tower
HP Z200
HP Z210
Last two have headers so make sure the port is on the back as it can be removed and is hard to find.
If you want new with parallel port, there is an MSI Tomahawk with B450 or B550 chipset that has a parallel port header, for AMD, but the price for the board only is still higher than the full PC mentioned above.
That can be from interference on parallel port, easily.I understand that any computer will do but with my previous set up I've ran into issues with the actual computer being unstable. Halfway threw cutting the thing crashes complete freeze up.
With parallel port?I am looking for a computer that is able to handle being left on for days on end no instability.
HP Z200
HP Z210
- RNJFAB
- Thank you received: 59
30 Dec 2024 22:18 #317688
by RNJFAB
Replied by RNJFAB on topic Building new plasma table
I recommend an old iMac.
I used a 2008 for my last CNC plasma, load it up with linux and bam! Money!!
My new CNC plasma is almost finished and I have just picked up a 2017 iMac for $300. I'm using it now just before I wipe it and load Linux.
Time to create page: 0.153 seconds
