Computer requirement
11 Jan 2025 17:21 #318697 by Jdolecki
Computer requirement was created by Jdolecki
Is there any requirement for building a Linuxcnc computer.
hd size
ram size
thanks john
11 Jan 2025 17:51 #318698 by tommylight
Replied by tommylight on topic Computer requirement
Anything above Core2Duo should do, 8GB of RAM (works OK with 4GB) and 32GB of disk space (HDD or SSD or NVME).
See here for some more info:
forum.linuxcnc.org/18-computer/38838-har...ency-tests-used-pc-s
And see here for some laptops that work, just do not bet on it as you might find the same model that does not work, i know i did
forum.linuxcnc.org/18-computer/54369-use...ernet-boards?start=0
11 Jan 2025 21:37 #318708 by rodw
Replied by rodw on topic Computer requirement
Later versions of Debian (we use debian 12 bookworm) requires careful optimisation on 2 core machines. I would suggest a 4 core Celeron, 4gb RAM, any sized SSD
12 Jan 2025 10:43 #318751 by JT
Replied by JT on topic Computer requirement
hd size
ram size
thanks john
Don't get stuck in the trap that you have to use the latest version of LinuxCNC my CHNC Lathe with an older motherboard runs fine with Ubuntu 10 and EMC 2.7 linuxcnc.org/dists/lucid/ I actually prefer the older EMC to LinuxCNC in most older machines as it's much more straight forward and not cluttered up with a dozen GUI's all competing to be the flashiest lol.
JT
The following user(s) said Thank You: rodw, Cant do this anymore bye all
12 Jan 2025 11:36 #318760 by rodw
just be aware that later hardware may need a later OS to get driver support.
  • Platinum Member
  • Platinum Member
12 Jan 2025 14:05 #318776 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Computer requirement
Maybe some kind of burnt offering or sacrifice as well. This is purely meant in jest.
Tho I think my "life choices ability" requires an exorcist or something.
Time to create page: 0.081 seconds
