Operating computers in the cold
- rdtsc
- Thank you received: 14
03 Feb 2025 16:38 #320508
by rdtsc
Replied by rdtsc on topic Operating computers in the cold
Desiccant sounds good at first, but these do "fill up" quickly. I have dozens of these bags in a 3D printer filament storage container. Even though it is completely sealed (with a gasket), all those bags are only good for about a year. Then they all must be baked at 110degC for 8-12h to rejuvenate them; moisture is insidious.
If you try this, place a quality hygrometer inside. Will likely find that the humidity stays low for only a month or so, even with a good seal.
The moisture alone probably is not causing the inability to start. The way most computers and power supplies are designed, just is not favorable to low temperatures. Very few are, because that is not a typical use case for a computer. Section 5.6 of the RaspberryPi4B says that is good down to 0degC - but then must consider whatever power supply is used for it. The characteristics of semiconducting materials changes as temperature changes, so functionality at low temps has to be something designed into it. Once had a quirky home computer that "complained" at 19degC and refused to run at 18.
If it were my machine, I'd put a heater (like a hair dryer on low setting) near the computer, along with a thermostat. Set the thermostat to say 20degC, and just let it warm up until the thermostat starts cycling. Of course need to be careful nothing can get too hot. Warming should take an hour or more - rushing it is not advised; the whole computer needs to warm up slowly. Then run the machine. That may be easier than re-engineering a quirky power supply or replacing the computer. Unless anyone knows of an industrial-rated computer (and power supply.)
- Dedeer
22 Feb 2025 19:32 #322297
by Dedeer
Replied by Dedeer on topic Operating computers in the cold
One Solution is to get a industrial second Hand PC. I have a Beckhoff which i use with my machine for about 4-5years now and Not a Single Problem. And where i live Temperatures are as low as -10C in Winter.
- Thank you received: 7488
22 Feb 2025 20:38 #322305
Last night one of my 3D printers panicked as it got under 0 in the shop, the shops are not isolated at all and have small open windows, no issue with cold ever, but lots of issue with moisture.
Replied by tommylight on topic Operating computers in the cold
Same here, mostly, can go down to -27 every 2-4 years and -37 twice in my lifetime ( i am old)And where i live Temperatures are as low as -10C in Winter.
- Jdolecki
- Thank you received: 12
22 Feb 2025 22:45 #322318
by Jdolecki
Replied by Jdolecki on topic Operating computers in the cold
Hard drives dont like cold.
And if you running them out on the floor make sure you have a backup of the HD cause one day you gonna turn it on and it’s gonna say no HD found.
23 Feb 2025 00:35 #322326
I think 5 to 45C is their normal working environment temperature, but fast ones do get hot while working.
True, but i would venture a guess that up to -5C should still be OK on older drives and 0C on new-ish drives. Never tested, though as SSD are not so sensitive and i do not have HDD to test with.Hard drives dont like cold.
- Jdolecki
23 Feb 2025 02:47 #322335
by Jdolecki
I had two hard drive stop working in my un heated
Now my mill has an intel nuc with solid state HD.
- rdtsc
05 Jul 2025 17:00 #331330
by rdtsc
Indeed Dedeer, Beckhoff has recently released a series of PCs specifically for real-time Linux: www.beckhoff.com/en-us/company/press/twi...linux-r-2024-04.html
Time to create page: 0.097 seconds
