Raspberry with LinuxCNC direct interface
10 months 4 weeks ago #339670 by elovalvo
I wonder, is there a Raspberry HAT that can direct interface with a stepper driver ?
Jonh.
www.instructables.com/LinuxCNC-on-Raspbe...i-With-GPIO-Control/
10 months 4 weeks ago - 10 months 4 weeks ago #339672 by EdWorks
I've just been down that road (at least one of them):
forum.linuxcnc.org/9-installing-linuxcnc...aughter-board#339636
Last edit: 10 months 4 weeks ago by EdWorks. Reason: Attachment
9 months 2 weeks ago #341522 by diy
9 months 2 weeks ago #341528 by unknown
If using the RPi Trixie image you will need to update Linuxcnc to 2.9.8.
This will be the situation until late March\early April.
6 months 3 weeks ago - 6 months 3 weeks ago #345251 by masawee
i think NOT need this HAT, i think can build own "hat" mean connect to gpio pins shift level converter tx108 chip module, input is 3,3V and this module convert output to 5V and this 5V signal can wired to stepper driver board DM556 etc, step pin and dir pin and enable pin. but problem have how i setting rpi4 linuxcnc all gpio pins ? rpi4 and has installed linuxcnc but if looking have only config wisard and this can only setting paraller port pins, and pnconfig tool has only how setting mesa card pins, i not understand how can setting rpi4 gpio pins all step, dir, enable and all input pins home, e-stop, limits, probe, etc pendant encoder, rotary SW, axis select, scale select. i have installled linuxcnc to rpi4 and software/image working ok, but how setting gpio pins ?
Last edit: 6 months 3 weeks ago by masawee.
6 months 3 weeks ago #345253 by meister
Untested
File Name: rpi4-stepper.zip
File Size:597.68 KB
The following user(s) said Thank You: NWE
