Error finishing read... *sigh*
- SebastianM
- Thank you received: 3
14 Jun 2025 16:44 #330278
by SebastianM
Error finishing read... *sigh* was created by SebastianM
Hello everyone.
I know there are plenty of other threads about this topic, and I think I read them all, still I struggle to solve the issues that I am having.
My setup is:
Most of the time the system errors out right after startup with "error following read...". Sometimes I am "lucky" and it works for maybe 5minutes before it errors out.
What I did so far (after reading in this forum for 2 nights):
regards and thx.
Sebastian
My setup is:
- Dell Wyse 5070 with Celeron J4105 4-core cpu THIN CLIENT
- realtek onboard NIC
- fresh Linuxcnc 2.9.3 install
- brandnew Mesa 7i76eu, flashed with pktUART firmware
- I ran sudo chrt 99 ping -1.001 -q 10.10.10.10 to get some statistics. Here is the result:
179555 packets transmitted, 179555 received, 0% packet loss, time 180656ms
rtt min/avg/max/mdev = 0.052/0.065/8.974/0.036
- disabled all BIOS options regarding power management, hyperthreading, ... etc
- Installed R8168-dkms driver (sudo apt-get install r8168-dkms)
While searching in this forum, I found that some people had to install linux headers first. I did not do that.
When I run a script to identify the used drivers (JCW posted this somewhere a while ago), i get the followig result:
./edriver.txt
xargs: warning: options --max-args and --replace/-I/-i are mutually exclusive, ignoring previous --max-args value
enp1s0 : r8169
wlp0s12f0 : iwlwifi
Is this result "expected? Or did the driver installation not work?
Other people posted that they had to install linux-headers and purge the old driver...
- then I found a script that JCW posted in another thread that pins the IRQ somewhere (I honestly dont really understand whats behind this, but still this is the output):
cnc@linuxcnc:~/gcodes$ sudo ./pinirq.txt enp1s0
Cores: 4
Old CPU Mask: f
Set device enp1s0 IRQ 122 CPU mask to 8
However, it did not improve my ping / latency at all. Do I need to do anything prior to that? Isolating something?
- editing the kernel parameters in grub customizer (quiet isolcpus= 3 pcie.aspm=0 r8168.eee_enable=0 pcie_aspm=off idle=poll).
I dont really understand what this does, therefore I hesitated to run it. - ....
regards and thx.
Sebastian
- Thank you received: 5330
14 Jun 2025 18:12 #330279
Replied by PCW on topic Error finishing read... *sigh*
Definitely do the grub (kernel command line) change, also the pinirq script will have
minimal effect unless you add the isolcpus line.
- SebastianM
14 Jun 2025 19:09 - 14 Jun 2025 19:21 #330280
by SebastianM
Replied by SebastianM on topic Error finishing read... *sigh*
No idea if I did anything wrong, but after I applied that line from above and rebooted, Debian won’t launch the desktop environment anymore. I can manually start xfce. Never mind
Last edit: 14 Jun 2025 19:21 by SebastianM.
- SebastianM
14 Jun 2025 19:20 - 14 Jun 2025 19:21 #330281
by SebastianM
Alright. I applied that command in the grub configurator, rebooted and ran the pinIRQ script again.
ping times look much better (dropped from 8 to 1.2), but I am still too high... right?
first
Cores: 4
Old CPU Mask: f
Set device enp1s0 IRQ 121 CPU mask to 8
then
cnc@linuxcnc:~/gcodes$ sudo chrt 99 ping -i .001 -q 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
^C
--- 10.10.10.10 ping statistics ---
142832 packets transmitted, 142831 received, 0.000700123% packet loss, time 143400ms
rtt min/avg/max/mdev = 0.056/0.108/1.211/0.035 ms
first
Cores: 4
Old CPU Mask: f
then
^C
14 Jun 2025 19:52 #330282
Might be usable with a 2 ms servo thread.
I would check how LinuxCNC runs now
- SebastianM
14 Jun 2025 20:05 - 14 Jun 2025 20:07 #330283
by SebastianM
Thx Peter. Really appreciate your help. Last question …. Can you tell if my realtek nic is using the dkms driver or not? I attached the output of a script that you posted somewhere.Like I said in the first posting, I didn’t know that Linux headers might have been necessary when I installed dkms.
Last edit: 14 Jun 2025 20:07 by SebastianM.
- DMNZ
- Thank you received: 8
14 Jun 2025 23:56 #330289
by DMNZ
Replied by DMNZ on topic Error finishing read... *sigh*
after installing the driver run this to check that it is the right one being used:
sudo lspci -v
under Realtek controller check Kernel driver in use, it should be r8168. (see attached screenshot)
to avoid problems i suggest to blacklist the r6169 driver completely in grub by adding: modprobe.blacklist=r8169
or, since your pc looks similar to mine you can add the whole my line to /etc/default/grub which through trial and error i found the most stable:
GRUB_CMDLINE_LINUX="irqaffinity=0-1 kthread_cpus=0-1 isolcpus=domain,managed_irq,2-3 rcu_nocb_poll pcie_aspm=off r8168.aspm=0 r8168.eee_enable=0 modprobe.blacklist=r8169,mei_txe"
don't worry it will not kill your pc it just rebalance your cores to do different things.
dont forget to run "sudo update-grub" to update grub configuration otherwise you won't see any changes after restart.
also check sudo dmesg for any errors during boot.
having 1.2ms ping once in a blue moon won't kill you. i suggest to add "grep -v time=0." to see how many actual pings you got over 1ms.
i normally run something like this:
sudo chrt 99 ping -i 0.001 -q 10.10.10.10 -c 1800000 | grep -v time=0.
this will run ping for 30 minutes with 1ms pings and only show you the pings that took longer then 0.999 ms.
if you see only one or two 1.2 ms in 30 minutes it is not a problem, 8ms is super bad though.
have fun!
sudo lspci -v
have fun!
The following user(s) said Thank You: SebastianM
- SebastianM
15 Jun 2025 03:57 #330292
by SebastianM
thank you, that is very helpful.
By running "sudo lspci -v", I could confirm that the right driver is used (see attachment).
But when I try to run the modified ping command, the result is just the same as before. It doesnt filter out any packets over 1ms... again, see screenshot.
I guess the command has to be modified a bit...
Regards and thank you
Sebastian
Sebastian
- DMNZ
15 Jun 2025 05:32 #330295
by DMNZ
sorry, my bad, you should remove that -q in the command which makes your ping output quiet. try this:
sudo chrt 99 ping -i 0.001 10.10.10.10 -c 1800000 | grep -v time=0.
btw. are you still getting that error finishing read?
- SebastianM
15 Jun 2025 13:27 #330306
by SebastianM
Thx.
Can’t tell if I still get would that error as I took the mesa out of the workshop and back into my “office” for bench testing and debugging.
Will apply the grub parameters today that you posted.
Currently I do have the following code in my grub customizer (guess I have to remove it).
The arguments are slightly different (isolcpus 3 vs 2,3), but let’s see.
Time to create page: 0.234 seconds
