Trouble with LinuxCNC and Gantry stepper motor setup.
- jimmyrig
- Thank you received: 42
16 Jul 2025 13:44 #331900
by jimmyrig
Replied by jimmyrig on topic Trouble with LinuxCNC and Gantry stepper motor setup.
Ahhh,
When you say run y axis and a axis in tandem do you mean you have a 4th rotary axis (for cutting pipe) or just have 2 motors on the gantry that you need to move together?
For the first see my comment above......
For the second
Make a new config, select your "a axis" as tandem Y.
You will need homing switches on each of the 2 y axis so the joints can square themselves before becoming an axis. Once they are homed both will move at the same time and jog like normal.
No gcode changes for this one.
For the second
- Revinvoss
22 Jul 2025 14:04 #332182
by Revinvoss
Replied by Revinvoss on topic Trouble with LinuxCNC and Gantry stepper motor setup.
So, I will need to install physical limit switches to the table for this homing setup?
Is there a tutorial and were for wiring limit switches correctly to the control board ST-V3. As I do not have any switches install at this time. It never needed them when I had the table setup for Plasma cutting. Now I have changed to Router it seems that this is an issue.
- Thank you received: 5330
22 Jul 2025 14:27 #332184
Replied by PCW on topic Trouble with LinuxCNC and Gantry stepper motor setup.
You do not absolutely need to have switches on a gantry
but if not, you need to use an "immediate" homing setup:
linuxcnc.org/docs/html/config/ini-homing.html#_immediate_homing
The following user(s) said Thank You: Revinvoss
Time to create page: 0.264 seconds
