- Thank you received: 84
LinuxCNC uses minimal RAM, but I could see needing lots of RAM if you were running CAD/CAM software on the machine and working with larger files. If that is the case you might want the kind of computing power you're talking about.However I’m a bit limited by the low ram (8GB), low disk space and etc.
