- Thank you received: 3
Tool offset patch
- LAIR82
14 years 1 month ago #24427
by LAIR82
Replied by LAIR82 on topic Re:Tool offset patch
John,
I hope your not getting irritated,
Here is what I get when I try to apply the patch, and How do I change directories,
srt@Cinci:~$ git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev
Initialized empty Git repository in /home/srt/linuxcnc-dev/.git/
remote: Counting objects: 110912, done.
remote: Compressing objects: 100% (25444/25444), done.
remote: Total 110912 (delta 87482), reused 107589 (delta 84515)
Receiving objects: 100% (110912/110912), 59.80 MiB | 235 KiB/s, done.
Resolving deltas: 100% (87482/87482), done.
srt@Cinci:~$ git am --signoff tool-change.patch
fatal: Not a git repository (or any of the parent directories): .git
srt@Cinci:~$ git am --signoff 0001-Fanuc-style-tool-change-for-Lathes.-On-Fanuc-control.patch
srt@Cinci:~$
srt@Cinci:~$
- BigJohnT
- Thank you received: 994
14 years 1 month ago #24428
by BigJohnT
Replied by BigJohnT on topic Re:Tool offset patch
When you open a terminal you are in your home directory. To change the directory you use "cd path to directory". So you need to do "cd linuxcnc-dev" then do a list to see if your file is there with "ls". The git patch command only works in a directory created by git.
Some good reading on basic linux terminal commands here .
- LAIR82
14 years 1 month ago - 14 years 1 month ago #24451
by LAIR82
Good Morning John,
I sat down and read thru the manuals you sent along with what I found about git and linuxcnc-git and am feeling a little better about what I'm doing, problem I am having is that I missed a step about checking for outstanding build dependencies, I did that step now, and I have some things need to get installed. I try to install and here is what I get;
srt@Cinci:~/linuxcnc-dev$ apt-get install dvipng
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
srt@Cinci:~/linuxcnc-dev$ sudo -i
[sudo] password for srt:
I entered the sudo -i and then it will not allow me to type to enter our password.
Last edit: 14 years 1 month ago by LAIR82.
- BigJohnT
14 years 1 month ago #24452
by BigJohnT
Great to see your making progress.
Anytime you use a command that requires root privileges you precede the command with sudo.
sudo apt-get install dvipng
will prompt you for your password then proceed to install the package.
- LAIR82
14 years 1 month ago - 14 years 1 month ago #24453
by LAIR82
I just tried that, It liked it, then It asked for the password, and when I try to enter my password, it doesn't do anything, the cursor stops blinking, stays solid black as long as I'm trying to type. No letters show up
I talked to my boss and he said that the letters will not show up.
Last edit: 14 years 1 month ago by LAIR82. Reason: Realized what I needed to do,
- LAIR82
14 years 1 month ago #24457
by LAIR82
I am having problems applying the patch now, here is what it is saying
srt@Cinci:~/linuxcnc-dev$ git am --signoff 0001-Fanuc-style-tool-change-for-Lathes.patch
previous rebase directory /home/srt/linuxcnc-dev/.git/rebase-apply still exists but mbox given.
Time to create page: 3.109 seconds
