New gcode cycle
13 years 3 months ago #36822 by ArcEye
Replied by ArcEye on topic New gcode cycle
Not quite with you on this, can you explain a bit further.
Are you trying to get #5410 into your GCode or your python code?
The following user(s) said Thank You: jlviloria
13 years 3 months ago #36825 by jlviloria
Replied by jlviloria on topic New gcode cycle
www.linuxcnc.org/docs/devel/html/gcode/o...umbered_parameters_a
I'll try, patience with my English.
in NGCGUI can "import" parameters 5410, 5411, 5412, 5413, as follows:
#<tool_rad> = [# 5410/2]
in python with remap, as I can do?
13 years 3 months ago #36826 by ArcEye
I think you want to access it from python?
I don't know about python, but it is accessible in C from emcioStatus.tool.toolTable[x].diameter
If you look through the python / C bindings there is an equivalent to the C code
emcioStatusBuffer = new RCS_STAT_CHANNEL(emcFormat, "toolSts", "tool", emc_nmlfile);
to get the status buffer and access the information
I think you will find it in ../src/emc/usr_intf/axis/extensions/emcmodule.cc
13 years 3 months ago #36840 by BigJohnT
Replied by BigJohnT on topic New gcode cycle
This may or may not be what your looking for:
www.linuxcnc.org/docs/html/common/python...xcnc_stat_attributes
The tool table and tool offsets can be obtained with the python interface.
JT
The following user(s) said Thank You: ArcEye, jlviloria
13 years 3 months ago #36854 by ArcEye
Yet another document I didn't know existed
That is certainly the library I meant
13 years 3 months ago - 13 years 3 months ago #37004 by jlviloria
ArcEye,
looks like will work, I had some problems with radios, is the only way I've been able to focus the cycle.
G18 G8
G1.1 Q47 X5 Z-10
G1.1 Q47 X10 Z-15
G1.1 Q47 X30 Z-25
G1.1 Q47 X40 Z-35
G1.1 Q47 X52 Z-50
G0 X55
Z2
G71 Q47 P1 R0.5 F1500
m2
each line is a segment of the cycle, but not registered as such.
I'm unintentionally the Mazatrol programming, with difference Mazatrol conversational language used.
Jorge Viloria
Last edit: 13 years 3 months ago by jlviloria.
The following user(s) said Thank You: ArcEye, Diederik
Time to create page: 1.799 seconds
