gcode format
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
13 Aug 2013 11:38 - 13 Aug 2013 11:40 #37610 by billykid
gcode format was created by billykid
Hello, I' m using linuxcnc 2.6.0 pre
executing this code, the x-axis start before reaching Z 5.
N6135 G3 X 133.9400 Y -138.0000 I -2.0000 J 0.0000 F800
N6140 G0 Z 5.0000
N6145 X 166.5000
correcting the third row so the fault disappears.
N6145 G0 X 166.5000
already happened to someone?
Last edit: 13 Aug 2013 11:40 by billykid.
13 Aug 2013 11:56 #37611 by ArcEye
Replied by ArcEye on topic gcode format
Hi
Although G00 and G01 should be modal, I always head each line with the relevant code for readability if nothing else.
It is strange, only thing that occurs is was the file created under windoze? (or the output from a windoze CAM program)
If it does not have linux line termination and the next line does not have another modal code, the third line could be being read as part of the second line.
When a modal code of the same group is encountered, it is treated as another line again possibly.
  • billykid
  • Platinum Member
  • Platinum Member
13 Aug 2013 12:19 #37613 by billykid
Replied by billykid on topic gcode format
thanks for the quick reply!
the file has been generated by DeskCNC under Windoze 7.
the first impression for me was just what you said ..
is performed together with the previous line
13 Aug 2013 13:14 #37616 by BigJohnT
Replied by BigJohnT on topic gcode format
Also you can turn off the line numbers as Linuxcnc just ignores them.
JT
13 Aug 2013 13:51 - 13 Aug 2013 13:52 #37617 by ArcEye
JT
Indeed, it really clutters the code too.
I use this script to do it
#!/bin/bash
## inserts or removes line numbers at start of each line
## usage: linenumbers insert oldfile newfile
##        linenumbers remove filename  (overwrites so perform on a copy)
case $1 in
    insert )    exec < $2
                d="N"
                e=" "
                a=1
                while read LINE ; do
                    c=$d$a$e$LINE
                    echo $c >> $3
                    ((a++))
                done ;;
    remove )    sed -i "s/^ *N[0-9]* //g" $2 ;;
esac
exit 0
It overwrites, so always use it on a copy of the code to be safe
Last edit: 13 Aug 2013 13:52 by ArcEye.
The following user(s) said Thank You: BigJohnT
13 Aug 2013 13:52 #37618 by BigJohnT
That's pretty neat!
JT
  • billykid
  • Platinum Member
  • Platinum Member
13 Aug 2013 20:53 #37633 by billykid
but removing the line numbers will always have the problem or not?
Mauro
13 Aug 2013 21:19 #37636 by ArcEye
It will make no difference to operation,
just make your files smaller and easier to read
  • billykid
  • Platinum Member
  • Platinum Member
13 Aug 2013 22:58 #37638 by billykid
but in my case it does not change anything
Mauro
14 Aug 2013 09:56 - 14 Aug 2013 10:08 #37647 by ArcEye
I am not sure if you are saying the script does not work (which it does) or that removing line numbers does nothing regards your original problem.
It certainly does not affect the latter.
Can you zip the file you are using and attach it so that we can look at it and try it to see if we get the same problem
It is possible you have uncovered a bug with the interpreter, changes made in one area could have an unforseen knock on effect on modality.
(however I cannot reproduce it without playing with G64, my moves go to the end before the next line is executed whether I have a modal code in them or not)
Last edit: 14 Aug 2013 10:08 by ArcEye.
The following user(s) said Thank You: billykid
Time to create page: 0.142 seconds
