gcode format
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
14 Aug 2013 10:26 #37649 by billykid
Replied by billykid on topic gcode format
I'm trying to solve the problem just figured out I will inform you via the defective file.
I'm always using g64 without options
Mauro
14 Aug 2013 10:41 #37650 by ArcEye
Replied by ArcEye on topic gcode format
If you run at high speed feed with G64 set with no options, you will get significant rounding over of corners, where the next line starts effectively before the current one finishes.
If you set G64 P0.1 to go within 1/10th mm of every point, does this effect what you are seeing?
The following user(s) said Thank You: billykid
  • billykid
  • Platinum Member
  • Platinum Member
14 Aug 2013 12:06 #37654 by billykid
Thank you very much!
I tried G64 P0.1 and it works perfectly without any problems the same gcode.
strange that after modification with gedit decreased the defect ..
Mauro
Time to create page: 0.078 seconds
