newbie tool diamter compensation problem
- spskeyes
12 years 4 months ago #48173
by spskeyes
newbie tool diamter compensation problem was created by spskeyes
Hi All,
I am new to cnc and trying to engrave a square (0.5 in. x 0.5 in. outside edge) into aluminum with a sherline 3-axis cnc mill using tool diamteter compensation. The program is below, created with the help of inkscape. It works perfectly, the square is exactly the size i want, except that the last cut line overshoots on the Y axis by about 1/2 the tool diameter. Can anyone see what I have done wrong?
Thanks!
(Header)
(Generated by gcodetools from Inkscape.)
(Using default header. To add your own header create file "header" in the output dir.)
M3
(Header end.)
G21 (All units in mm)
(Start cutting path id: rect3473)
(Change tool to Default tool)
G00 Z5.000000
G42 D1
G00 X0.074466 Y12.625551 (comp intro line)
G01 Z-0.125000 F100.0(Penetrate)
G01 X12.625534 Y12.625551 Z-0.125000 F400.000000
G01 X12.625534 Y0.074480 Z-0.125000
G01 X0.074466 Y0.074480 Z-0.125000 (this line overshoots position reached at comp intro line by about 1/2 tool diameter)
G00 Z5.000000
(End cutting path id: rect3473)
(Footer)
M5
G00 X0.0000 Y0.0000
M2
(Using default footer. To add your own footer create file "footer" in the output dir.)
(end)
Thanks!
(Header)
M3
(Header end.)
G00 Z5.000000
G42 D1
G00 Z5.000000
(Footer)
M5
G00 X0.0000 Y0.0000
M2
(end)
- ArcEye
- Thank you received: 240
12 years 4 months ago #48181
by ArcEye
Replied by ArcEye on topic newbie tool diamter compensation problem
Hi
This would be a very good project to learn coding by hand, CAD/CAM seems overkill.
I am not sure exactly what dimensions you started with, it looks as though you are using cutter comp and adjusting the coordinates.
If you write a simple program to cut a 12.5mm square like so
Because you have told the interpreter that the cutter diameter is 1mm and you want to stay to the right side of the line (G42 D1)
all you need to do is program the finished size you actually want, in this case 12.5 mm
The plot from the cut below shows that it takes a course 0.5mm inside the line all the way around
G40 G90
G54
G21 G17
G8
S600 M3
G00 Z5.000000
G42 D1
G00 X0 Y12.5
G01 Z-0.125000 F100
G01 X12.5 Y12.5 F400
G01 X12.5 Y0
G01 X0 Y0
G01 X0 Y12.5
G00 Z5
G40
M5
G00 X0 Y0
M2
- spskeyes
12 years 4 months ago - 12 years 4 months ago #48182
by spskeyes
Replied by spskeyes on topic newbie tool diamter compensation problem
Thanks for the reply. The example code you supplied does the same overshoot on the same cut. It seems like something is wrong with my configuration external to the program.
The tool is 0.0mm length and 3.175mm diameter. I think G42 D1 specifies the first tool in my tool list (which is what I want), not a tool with diameter 1mm.
I have been able to get the cut I want by turning off tool compensation and turning it back on right before the cut that always overshoots. The resulting code looks like this:
This should no be needed. Any idea what the problem might be?
G40 G90
G54
G21 G17
G8
S600 M3
G00 Z5.000000
G42 D1
G00 X0 Y12.5
G01 Z-0.125000 F100
G01 X12.5 Y0
G01 X0 Y0
G40 (added this)
G42 D1 (added this)
G01 X0 Y12.5
G00 Z5
G40
M5
G00 X0 Y0
M2
Last edit: 12 years 4 months ago by spskeyes. Reason: More information
- ArcEye
12 years 4 months ago #48186
by ArcEye
Well unfortunately you are wrong, D stands for diameter
www.linuxcnc.org/docs/html/gcode/gcode.html#sec:G41_1-G42_1
I am rather unsure as to why the first 3 sides would not have overcut.
The other alternative is to program 12.5mm minus cutter radius, with no cutter comp, does this overcut?
If so there may be something more fundamentally wrong
- spskeyes
12 years 4 months ago #48189
by spskeyes
No, I am not wrong. In my context D stands for tool number:
www.linuxcnc.org/docs/html/gcode/gcode.html#sec:G41-G42
There is no overcut when I don't use cutter comp.
- ArcEye
12 years 4 months ago #48194
by ArcEye
Apologies, think I had word blindness.
I was looking at 42 D1 and seeing 42.1 D1, even in my prog :blush:
Time to create page: 0.363 seconds
