newbie tool diamter compensation problem
12 years 4 months ago #48195 by Rick G
Replied by Rick G on topic newbie tool diamter compensation problem
As ArcEye showed it is a good idea to start the program with a preamble that puts the machine in a know state...
G40 G90 G54 G21 G17 G8
What position is the machine in when you start the program?
perhaps try changing this...
(Header)
(Generated by gcodetools from Inkscape.)
(Using default header. To add your own header create file "header" in the output dir.)
M3
(Header end.)
G21 (All units in mm)
(Start cutting path id: rect3473)
(Change tool to Default tool)
G00 Z5.000000
G42 D1
G00 X0.074466 Y12.625551 (comp intro line)
....rest of program
To
(Header)
M3
(Header end.)
G00 Z5.000000
G42 D1
G00 X-2 Y10
...rest of program
Are you using backlash compensation?
Rick G
12 years 4 months ago #48203 by spskeyes
Replied by spskeyes on topic newbie tool diamter compensation problem
Thanks Rick G I had tried adding in another move like that already but it didn't help. I start the program with the machine in the home (0,0,0) position.
The overshoot always happens on the last cut / edge of the square. However, if I continue on to re-trace half of the fist cut (first edge of the square) then the machine won't overshoot because it follows a previous cut
G01 X0.074466 Y0.074480 Z-0.125000 (this line overshoots position unless I add the next line)
G01 X12.625534 Y6 Z-0.125000 (Y6 is about half the line already cut on the first pass)
I found an example of cutting out the inside profile of a square with tool comp and they seem to arc in and out of the cut. I'm not sure why this is needed but I guess its what i have to do. See Figure 5 here:
linuxcnc.org/docs/html/gcode/tool_compensation.html#_examples
Time to create page: 0.867 seconds
