[solved]Unable to WRITE float pin OUT
11 years 10 months ago #54076 by ArcEye
Replied by ArcEye on topic Y[#40 + #<_hal[mycomp.newyvalue]>]
problem2: tcomp.vx1/2 is OK AND WORK PERFECT
tcomp.vy2/1 never updated ... why??????
The obvious difference is that the x values are set and always the same, so they will work.
You transfer the value to cx but never use it?
I would be debugging by printing out the contents of 'value' and cx, even though it will soon fill the terminal, just to see what is happening and if there is some way of printing the encoder output to compare do that too.
The following user(s) said Thank You: bkt
11 years 10 months ago - 11 years 10 months ago #54077 by bkt
Replied by bkt on topic Y[#40 + #<_hal[mycomp.newyvalue]>]
ok ... I had it figured out I also .... but I not undesrtand why .... how cat printf to terminal the result?? I use rtapi_print ... but how terminal call??
Last edit: 11 years 10 months ago by bkt.
11 years 10 months ago - 11 years 10 months ago #54085 by bkt
ok I run linuxcnc from terminal whit "linuxcnc mydir/mymachine.ini" ...... after some row I have an error:
........ ........ Sratting Linuxcnc .... ERROR: channel 0 realtime part is not loaded
no other .... but in my tcomp I have already insert
rtapi_print("cx, %3.2f", cx);
at this point I think the tcomp work without realtime.
I don't know the origin of this error..... :blush: :blush:
OK OK my mystache .... i have not cancel loadrt halsampler that not use yet.
But not print value in my terminal ....
11 years 10 months ago #54086 by bkt
I find debug set ......
Ok the terminal fills up early ... but if I see all EMC_TRAJ_LINEAR_MOVE .... i see only GCode coordinate or coordinates that originate from the numbers and not by the variablexample:
FUNCTION(_){ float cx = 0; cx = valy; vx1 = 40.0; <----real x value vy1 = cx - 40.0; <----real y value vx2 = -200.0; <----real x value vy2 = cx - 300.0; <----real y value CX value seems to be always 0 }
11 years 10 months ago #54087 by bkt
debug terminal ....
File Name: k-1-debug.txt
File Size:40 KB
11 years 10 months ago #54091 by bkt
ok I close the discussion ... the component works well ... that's what I try to do that's not good
Time to create page: 0.211 seconds
