- Thank you received: 114
Full circle arc with offset problem?
- Rick G
10 years 5 months ago #75113
by Rick G
Replied by Rick G on topic Full circle arc with offset problem?
Seams to me this discrepancy has come up before with inch, metric , tool table, etc.
I find that I get similar results as you do when running the axis mm sim BUT when running the AXIS sim error codes are generated.
Rick G
Rick G
- Rick G
10 years 5 months ago #75242
by Rick G
It appears that if the [TRAJ] section of the ini file contains...
LINEAR_UNITS = mm
The complete move is not made and no error code is issued.
However if the [TRAJ] section of the ini file contains...
LINEAR_UNITS = inch
An error code is generated.
Rick G
LINEAR_UNITS = mm
LINEAR_UNITS = inch
Rick G
- SrLange61
- Thank you received: 5
10 years 5 months ago #75271
by SrLange61
Replied by SrLange61 on topic Full circle arc with offset problem?
Change the cutter compensation back to a 1/8 bit. So the D value after G42.1 is .125 instead of 3.17 in metric.
The next move is still missing here using axis.ini.
srl
srl
- SrLange61
10 years 4 months ago #75614
by SrLange61
After reading the Gcode guide I removed the G2 and X -Y as they had not changed value.
Still no joy with line N60.
srl
10 S20001 M3
N20 G00 Z100
N30 X109.2826 Y40.1466
N40 Z20
N50 G42.1 D3.17 G02 X117.2813 Y40 Z2.6 I3.9993 J-0.0733 F400
N60 I-27.2813 J0 (problem here. add P2 or remove G42.1 and its fine)
N70 X109.2826 Y39.8534 Z20 I-3.9993 J-0.0733
N80 G40 G01 X113.282 Y39.9267
N90 G00 Z100
N100 M30
srl
- Skullworks
8 years 11 months ago #101304
by Skullworks
Replied by Skullworks on topic Full circle arc with offset problem?
Your error is line N50
You cannot activate cutter comp in a G2/G3
So
N30 X100 Y42 (random location)
N40 Z20
N50 G1 G42.1 D3.17 X109.2826 Y40.1466 F400.
N55 G2 X117.2813 Y40 Z2.6 I3.9993 J-.0733
rest is fine.
Try this
G0 G54 G90 G91.1 X0 Y0 S10000 M3
G43 Z1 H1
G01 Z-1 F80
G1 G41.1 D5. X15 Y5. F200
G3 X0 Y20 I-15 (J0) *zero values not needed in incremental arc center mode
J-20
X-15 Y-15 J-15
G1 G40 X0 Y0
G0 Z1
M30
So
N40 Z20
rest is fine.
Try this
G43 Z1 H1
G01 Z-1 F80
J-20
X-15 Y-15 J-15
G1 G40 X0 Y0
G0 Z1
M30
Time to create page: 0.357 seconds
