G38.x and acceleration (not stopping)
10 years 4 months ago #75340 by arhi
Replied by arhi on topic G38.x and acceleration (not stopping)
yes, but having a different limit for different operations also makes sense
Thanks for the HAL pins tip, off to gogle :D
10 years 4 months ago #75359 by arhi
andypugh wrote: You could look at changing the limit "on the fly" look for HAL pins called "ini.***". You could pass different values to those prior to a probe move.
www.linuxcnc.org/docs/2.7/html/remap/rem...i_file_configuration
enable #<_ini[section]name> read only variables: 4
if set, the interpreter will fetch read-only values from the ini file through this special variable syntax.
enable #<_hal[Hal item]> read only variables: 8
if set, the interpreter will fetch read-only values from HAL file through this special variable syntax.
here it's said they are readonly .. I know how to read the ini.0.maxacceleration but how to write to it?
I doubt this is going to happen in sw .. will have to do it in hw :(
10 years 4 months ago - 10 years 4 months ago #75362 by andypugh
Replied by andypugh on topic G38.x and acceleration (not stopping)
arhi wrote: www.linuxcnc.org/docs/2.7/html/remap/rem...i_file_configuration
That's a different thing.
That is reading values from the INI file into G-code.
I was talking about the HAL pins such as ini.0.maxacceleration which you can manipulate in HAL.
For a first-cut. In the HAL file
net Z-accel motion.analog-out-00 => ini.2.maxacceleration
Then in the G-code you can change the value with an M68 code.
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m68
Last edit: 10 years 4 months ago by andypugh.
The following user(s) said Thank You: arhi
10 years 4 months ago #75369 by arhi
great I understood those are the same ... read already about m66 and m68 but I don't get the "E 0 to 3" is this the ## from motion.analog-out-## ?
will try immediately :D (it's 3:30am so will be running dry or my wife will throw me out but enough to see if it passes the syntax test :D )
10 years 4 months ago - 10 years 4 months ago #75371 by dgarrett
Replied by dgarrett on topic G38.x and acceleration (not stopping)
Please note that ini.* hal pins are created too late to be used
in a [HAL]HALFILE (but they can be specified in a [HAL]POSTGUI_HALFILE
if the chosen gui supports it or in independent applications that
access hal pins after starting LinuxCNC.
$ man milltask
These pins cannot be linked or set in a halfile specified
by [HAL]HALFILE. They can be altered by independent halcmd
programs or by GUIs that support [HAL]POSTGUI_HALFILE. The
inifile is not auto‐ matically updated with these values
but can be updated using the calibration program
(emccalib.tcl) when using a [HAL]POSTGUI_HALFILE.
Last edit: 10 years 4 months ago by dgarrett.
10 years 4 months ago - 10 years 4 months ago #75374 by arhi
andypugh wrote: For a first-cut. In the HAL file
not working :(
not a single ini.*.* is recognised, linuxcnc fails to start (not a pin...)
for e.g. this works
net lalala motion.analog-in-00 <= axis.0.backlash-vel
so I'm sure syntax is ok
but this is "not a pin"
net lalala motion.analog-in-00 <= ini.0.backlash
(or any other ini.*.* tried 5+ different ones)
@dgarrett, what you wrote explains why this don't work but I'm not sure I understand the "They can be altered by independent halcmd
programs or by GUIs that support [HAL]POSTGUI_HALFILE" ?! are you saying that I can create a M204 script that will change the ini.0.max_acceleration value using halcmd? I do not want to change the ini file, I just want to set new acceleration values for axis for "from M204 till another M204..) .. now I never made a Mxxx on the linuxcnc but iirc it's just a shell script that you can use to do whatever you want right? so halcmd blah blah blah ? any chance you can share a cmd that will change ini.0.max_acceleration value? :D
EDIT: looks like I can just halcmd net ... after linuxcnc started, now these pins are available ... any way to tell linuxcnc to exec a "Script" after loading?
Last edit: 10 years 4 months ago by arhi.
Time to create page: 1.238 seconds
