G38.x and acceleration (not stopping)
10 years 5 months ago #75259 by Rick G
Replied by Rick G on topic G38.x and acceleration (not stopping)
Suppose you had a switch that triggers at exactly .5"
You could set the switch on top of your workpiece and probe with the drill. Down at med speed, back up then slow probe down. (the switch has some overt travel to protect the drill)
The point that the switch triggers would then be .5" above the work. So you have found the top of the work without gouging the work piece.
Rick G
The following user(s) said Thank You: arhi
10 years 5 months ago #75260 by arhi
Replied by arhi on topic G38.x and acceleration (not stopping)
so I make the optical barrier with a hole, let dril go in, measure the distance between the "breakage and work" use that as offset.. should work, not nearly as simple but should work.. thanks!
10 years 5 months ago #75262 by arhi
btw just to confirm, me not finding a way to "override" acceleration for axis is correct, there's no way to do it with linuxcnc?
I ask because in "my cnc world" (3d printing) we use M201 (max acceleration during "work move"), M202 (max acceleration during "idle move"), M204 (default acceleration), GRBL also support "$120, $121, $122" for setting acceleration, never used it so not sure how that works and is is run-time or only configuration..
10 years 5 months ago #75264 by Rick G
It has come up before, but i know of no easy solution. I believe the best bet is to set up the machine for the best reliable acceleration and control the probe speed with the F command. The reason for a fast probe then a slow probe is to reduce the time of the probe if it has a long distance to go. If you get the probe close 1st then a slow probe which will stop faster than a fast probe is fine.
Rick G
10 years 5 months ago #75268 by arhi
Rick G wrote: It has come up before, but i know of no easy solution.
well if the M201/202/204 are not supported by the linuxCNC there's definitely no easy way to do it ... I'll figure something out in hw, just wanted to check if there are sw solutions first :)
10 years 4 months ago #75335 by andypugh
Replied by andypugh on topic G38.x and acceleration (not stopping)
arhi wrote: Yes, exactly what I want :D to stop "faster then set limit" ... is that possible?
No, because the whole point of the limit is to be, well, a limit.
You could look at changing the limit "on the fly" look for HAL pins called "ini.***". You could pass different values to those prior to a probe move.
Time to create page: 0.644 seconds
