- Thank you received: 486
Question re G76 threading code
- Clive S
10 years 3 months ago #77717
by Clive S
Ah I see my bad. I am in the process of removing the compound as you say it is not necessary.
Replied by Clive S on topic Question re G76 threading code
andypugh wrote: I was getting confused because I have not seen a CNC lathe with a compound slide.
(I have converted two manual lathes and removed the compound in both cases to increase stiffness)
- Clive S
5 years 2 months ago - 5 years 2 months ago #218131
by Clive S
I am sorry to open an old thread "but"
I would like some help with the G76 I,J and R commands
My small lathe cuts threads ok but on bigger threads and coarser pitches I would like to makes more passes.
This is the code I use for m10 thread
G0 X10 Z10
G76 P1.5 Z-12 I-0.1 J0.1 R1 K1.5 Q29.5 L0 H1
what controls the number of passes?
From the manual linuxcnc.org/docs/2.8/html/gcode/g-code.html#gcode:g76
I- - The thread peak offset from the drive line. Negative I values are external threads, and positive I values are internal threads. Generally the material has been turned to this size before the G76 cycle.
G0 X10 Z10
Last edit: 5 years 2 months ago by Clive S. Reason: Deleted some content that was incorrect
5 years 2 months ago - 5 years 2 months ago #218274
Replied by andypugh on topic Question re G76 threading code
R and J together control the number of passes, and then H spring-passes are added on top.
Fot coarser threads you can probably use the same J as you do already but set R to 2 so that the increments get progressively smaller.
Last edit: 5 years 2 months ago by andypugh. Reason: Make it make sense
- Clive S
5 years 2 months ago #218276
by Clive S
Thanks. But did you mean J to 2 or R to 2
I did read some ware (but can't find it again) that is was something like J/R that would make more passes !!
Fot coarser threads you can probably use the same J as you do already but set J to 2 so that the increments get progressively smaller.
5 years 2 months ago #218277
Edited. I did mean R.
Why not try threading some air and counting the passes?
- Clive S
5 years 2 months ago - 5 years 2 months ago #218279
by Clive S
I = 0.1 R = 1 gives 10 passes
I = 0.1 R = 1.2 gives 16 passes
I = 0.1 R = 2 gives too many to count
Yes of course I will.
Thanks for the input.
Last edit: 5 years 2 months ago by Clive S. Reason: corrected formatting + added data
Time to create page: 3.032 seconds
