Question re G76 threading code
10 years 3 months ago #77693 by Clive S
Replied by Clive S on topic Question re G76 threading code
andypugh wrote: The tool should be perpendicular to the work axis, or the thread will be the wrong shape.
Ok thanks for that.
So using a 60' tool perpendicular Q would be 29.5'
10 years 3 months ago #77697 by andypugh
Replied by andypugh on topic Question re G76 threading code
Q can be anything you want. But some numbers will work better than others.
Lots of debate here: www.practicalmachinist.com/vb/general/se...read-cutting-278289/
10 years 3 months ago #77703 by Clive S
andypugh wrote: Q can be anything you want. But some numbers will work better than others.
Yes Andy that is a good read. BUT it is still not clear (to me at any rate) if it refers to manual threading or CNC If you have the tool perpendicular to the job does the Q setting at say 29.5 use that angle with_cnc ie does linuxcnc move the tool in a the Q setting.
10 years 3 months ago #77706 by andypugh
I don't actually understand what you don't understand.
Q is a virtual compound slide angle. The thread forming tool necessarily has to be perpendicular to the work, or it won't form a thread.
10 years 3 months ago #77710 by Clive S
andypugh wrote: I don't actually understand what you don't understand.
Thank you for being so patient Andy You have just lit the light bulb for me. with the "Q is a virtual compound slide angle" I could not get my head around whether to physically set the compound on the slide to 29.5 or linuxcnc does it with the Q setting thus keep the physical compound at 0.
Thanks again.
10 years 3 months ago #77714 by andypugh
I was getting confused because I have not seen a CNC lathe with a compound slide.
(I have converted two manual lathes and removed the compound in both cases to increase stiffness)
Time to create page: 1.942 seconds
