Reading value of pin in g code
9 years 7 months ago #90361
Replied by andypugh on topic Reading value of pin in g code
How many do you have?
Maybe
And so on.
Maybe
(DEBUG, On Line 17: #5399)
And so on.
- Radek
9 years 7 months ago #90362
by Radek
Replied by Radek on topic Reading value of pin in g code
9 years 7 months ago #90367
It can't be stopping at line 4. It is executing line 8.
- Sjdc1982
- Thank you received: 3
9 years 7 months ago #90393
by Sjdc1982
Replied by Sjdc1982 on topic Reading value of pin in g code
just my two cents
but for me, i noticed when i tried to describe variables or use any of them i need to put them in this format
#<_variable>
or they won't work, IE maybe if you try
#<_4> = 0
(fyi i'm using nightly builds / pre releases as well and installed from the DVD image.)
#<_variable>
#<_4> = 0
9 years 7 months ago #90399
LinuxCNC supports two sorts of parameters (what might be called variables in an actual programming language, which G-code probably isn't).
#4 is a conventional mumerical parameter
#<myvariable> is a named parameter, an extension to the G-code standard supported by LinuxCNC
#<_myvariable> is a named paramter with global scope (which means that it has a value which can be used outside of the subroutine it is defined in)
#<4> is a named parameter. It will not necessarily have the same value as #4
#<_4> is another named parameter with global scope. It can have a different value to both #4 and #<4>
- Sjdc1982
9 years 7 months ago #90402
by Sjdc1982
and my idea does nothing lol, sorry just spit balling thought it was a issue with values/params not communication inside...
Time to create page: 0.195 seconds
