- Thank you received: 9
G Code Generation for Camshaft grinding
- massimodamassa
9 years 3 months ago - 9 years 3 months ago #96551
by massimodamassa
Replied by massimodamassa on topic G Code Generation for Camshaft grinding
Try putting G61 at startup
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g61-g61.1
Last edit: 9 years 3 months ago by massimodamassa.
9 years 3 months ago #96553
I don't think that there is anything wrong with the calculation, but I am unsure why you are doing it.
The INI file limits should match the machine capability, not be based on the desired speed. They are limits.
Replied by andypugh on topic G Code Generation for Camshaft grinding
TobiasKa wrote: Anyway I have just wrote down how I calculated the desired velocity of the system:
Maybe someone can point out where the flaw is in the calculation process?
9 years 3 months ago - 9 years 3 months ago #96555
This might be useful reading:
linuxcnc.org/docs/2.7/html/user/user-con...#_trajectory_control
Note that in this context the "naive cam detector" is detecting G-code from naive CAM software (lots of short straight moves) and has nothing to do with mechanical cams.
Last edit: 9 years 3 months ago by andypugh.
Time to create page: 0.162 seconds
