Grecode
- tryAndError
5 years 4 months ago #211920
by tryAndError
Replied by tryAndError on topic Grecode
I agree with you. I tried to install the branch but I ran into a problem. First, scratch links are not working so i tried rip installation. Then, when I came to the sudo make it stops, makefile:99: makefile.inc must specify rtprefix and other
- Thank you received: 2177
5 years 4 months ago - 5 years 4 months ago #211923
Replied by Aciera on topic Grecode
What information does this command give you:
[edit]
Unfortunately the scratch links on the buildbot page do expire after a certain time.
uname -a
[edit]
Last edit: 5 years 4 months ago by Aciera.
- tryAndError
5 years 4 months ago - 5 years 4 months ago #211933
by tryAndError
I will try that command in 7 days, I have some time off now but I am unpatient to see if it's going to work.
Last edit: 5 years 4 months ago by tryAndError.
5 years 4 months ago #212070
Replied by andypugh on topic Grecode
Have you seen the docs on automatic input filters? That might be a solution
linuxcnc.org/docs/2.8/html/config/ini-co...html#_filter_section
- tryAndError
5 years 4 months ago - 5 years 4 months ago #212544
by tryAndError
Linix debian 4.19.0-16-rt-amd64 # SMP PREEMPT RT Debian 4.19.181-1 (2021-03-19) x86_64 GNU/Linux
Aciera wrote: What information does this command give you:
Code:uname -a
[edit]
- tryAndError
5 years 4 months ago #212546
by tryAndError
I know about filter section but not sure how to use it for this purpose.
andypugh wrote: Have you seen the docs on automatic input filters? That might be a solution
Time to create page: 0.192 seconds
