REMAP M6 FOR GENEVA ATC
- COlger81
- Thank you received: 6
26 Oct 2018 14:25 #119447
by COlger81
REMAP M6 FOR GENEVA ATC was created by COlger81
I am remapping the tool change procedure and i need the spindle to come to a complete stop before executing python script. Any suggestions would be appreciated.
- Thank you received: 2181
26 Oct 2018 16:27 #119458
Replied by cmorley on topic REMAP M6 FOR GENEVA ATC
Are you asking for hardware solutions or software solutions?
A little more detail would be helpful.
Chris M
Chris M
- COlger81
26 Oct 2018 16:38 #119461
by COlger81
Replied by COlger81 on topic REMAP M6 FOR GENEVA ATC
Software. This is a Fadal with 21 tool changer. Which tool change pin fires first in IO control when M6 is executed?
- COlger81
26 Oct 2018 16:41 #119462
by COlger81
Also, where can i find the actual code that's executed during an M6 routine?
26 Oct 2018 17:29 #119471
Here is the over view of tool changes:
linuxcnc.org/docs/2.7/html/remap/remap.h...ange-currently-works
Look in src/emc/iotask/ioControl.cc for the HAL pin hand shaking
But I wonder if you 'AND' the tool-change pin with some sort of spindle stopped pin. (maybe even spindle at speed?)
Or feed the tool-change into a delay timer component.
Chris M
Chris M
- COlger81
26 Oct 2018 20:03 #119483
by COlger81
I was able to create a pin that gets triggered by the "tool-prepare" pin, which is the first pin activated by M6. I defined conditions in python as "while pin is active" and "spindle speed in == 0". Works great.
27 Oct 2018 01:24 #119496
Replied by andypugh on topic REMAP M6 FOR GENEVA ATC
I seem to say this a lot, but take a look at the sim/axis/vismach/VMC_toolchange configs. (You can run this on your current machine, it won't touch hardware, but has a 3D model of the machine).
I think that all you need is probably in there.
- COlger81
29 Oct 2018 16:18 #119602
by COlger81
I have the bulk of my ATC process done but i'm struggling with applying the carousel component "counter" to my changer. I have a fadal random 21 pocket changer. The sensor for counting tools is a single hall sensor connected to a BIT "true or false" input with magnets half way between each pocket.
29 Oct 2018 19:53 #119612
Is there an additional home sensor so that the machine knows where pin 1 is?
How did the original system know when to turn off the motor if the sensor is between positions?
- COlger81
29 Oct 2018 20:02 #119613
by COlger81
It does not have a home sensor on the turret. There's a detent at each pocket, the motor is shutoff at the halfway point when the magnets hit the sensor, the turret glides the other half and is grabbed by detent.
Time to create page: 0.233 seconds
