Please explain error measage
07 Mar 2019 00:18 - 07 Mar 2019 00:39 #127929 by Leon82
Replied by Leon82 on topic Please explain error measage
(comments) (like this)
may be your problem
change them to
(comments)
(like this)
if it works without error, you know they are the problem
ETA, I tested it in a Sim. Double comments are ok
Last edit: 07 Mar 2019 00:39 by Leon82.
  • allenwg2005
  • allenwg2005's Avatar Topic Author
  • Elite Member
  • Elite Member
07 Mar 2019 01:14 #127931 by allenwg2005
Replied by allenwg2005 on topic Please explain error measage
I think I have the Tool call sorted (could be wrong about that not sure about anything I'm doing).
Still have the error "Unknown word where unary operation could be".
What in the world is it telling me?
Here's the post out put:
( Test ATC ) ( File created: Wednesday March 06 2019 - 05:02 PM)
( for LinuxCNC )
( Material Size) ( X= 12.000, Y= 10.000, Z= 0.750)
G91 (Incremental distance mode)
G17 G20 (Active Plane: XY)(Inch Mode)
G40 G49 G80(Tool Diameter, Length compensation & canned cycles off)
G64 P0.05 Q0.05(Path Blending)
(M600)
M06 T1 End Mill (0.25 inch)
G90 (absolute distance mode)
G54 (Coordinate System)
S12000M5
G00 Z0.501
07 Mar 2019 01:16 - 07 Mar 2019 01:17 #127932 by Leon82
Double check the g64 line you've got 2 letters in there I think it's only a p.xxx
Last edit: 07 Mar 2019 01:17 by Leon82.
  • allenwg2005
  • Elite Member
  • Elite Member
07 Mar 2019 01:21 #127933 by allenwg2005
How much of the tool name should be in comments?
Now: M06 T1 End Mill (0.25 inch)
Should it be: M06 (T1 End Mill 0.250)
07 Mar 2019 01:24 - 07 Mar 2019 01:24 #127934 by Leon82
M6t1(comment)
Or t1m6(comment)
Last edit: 07 Mar 2019 01:24 by Leon82.
  • allenwg2005
  • Elite Member
  • Elite Member
07 Mar 2019 01:31 #127935 by allenwg2005
OK, answered my own question, it loads the file just fine when I edit to read M06 (T1 End Mill 0.250) .
Now, how do I get the post to output the tool line this way?
  • allenwg2005
  • Elite Member
  • Elite Member
07 Mar 2019 02:39 #127939 by allenwg2005
Those comments were a result of the tool name in the tool table, I have those changed and the file loads fine.
I have G00 [ZH} in the post but there is no mention of it in the gcode file,
Why wouldn't it write that to the file?
07 Mar 2019 03:04 #127941 by FariaAl
Replied by FariaAl on topic Please explain error measage
]Actually you do:
M1 G64 P0.05 Q0.05
(Begin Footer)
G00 Z0.501 <<<<< here, but this depends on a setting from the vectric job.
M30
(End Footer)
it can be set on the Toolpaths tab, Toolpaths Operations, Setup Materials and Rapid Gaps, might be different on Aspire.
I only use Vcarve as i an not able to run Aspire on Linux.
  • allenwg2005
  • Elite Member
  • Elite Member
07 Mar 2019 16:19 #127993 by allenwg2005
I didn't know Vcarve would run on a Linux box, interesting.
I'm puzzled, G43 tool length off-set usually H(and tool number) calls the negative off-set for the tool height.
In what way is that added to the code I have generated?
G00 Z 0.501 is a retract value for clearing material and other stuff (clamps for example), it isn't loading a specific tool length.
I have my post writing the way I expected it to at the moment, I just need to clear up this G43 issue and I have it.
Thanks for all the help so far.
07 Mar 2019 17:36 #128007 by MaHa
Replied by MaHa on topic Please explain error measage
If you want to use toollength from tooltable, add a G43 as below. The Z values in the tooltable should be positive.
(I hope this is the right section, and check the output)
+ Commands output for Initial rapid move
"G00 G43 [X] [Y] [Z] [F]"
Time to create page: 0.116 seconds
