Please explain error measage
- Thank you received: 7463
07 Mar 2019 18:58 #128013
sudo apt-get install vine
Replied by tommylight on topic Please explain error measage
I did try it some 5 years ago and it worked nicely . You just need to install vine before you try to install Vcarve.I didn't know Vcarve would run on a Linux box, interesting.
- allenwg2005
- Thank you received: 4
07 Mar 2019 19:11 #128014
by allenwg2005
Replied by allenwg2005 on topic Please explain error measage
This too gives me vales that move the tool, but I am still not loading the tool Z axis off-set.
My Fusion 360 ngc files have a ngc line that reads G43 Z0.xx H(tool number), it takes the offset value from the LinuxCNC Tool Table and offsets the tool given it's "Tool Touch Off" value.
Why isn't this Vetric post writing that code line?
My post has a call "G00 G43 [ZH]" in it, I must have something incorrectly written.
Thanks again
Thanks again
- allenwg2005
07 Mar 2019 19:16 #128016
by allenwg2005
Is that "vine" or Wine? (I haven't heard of vine but I don't know a lot of things).
I've never used Vcarve as a stand alone program, I bet you can't run Aspire in Wine, or with a beefy enough PC maybe you can..
07 Mar 2019 20:14 #128020
Do not bother with it, it is mainly used to do engravings from pictures.
Linuxc can run a lot of windoze stuff, it just might take a while to get them working in some cases.
Nothing can compensate for utterly useless and extremely bad coding done on some win software.
- allenwg2005
09 Mar 2019 14:33 #128164
by allenwg2005
There is a working PP attached at the end of "Post for Vectric W/ATC" now.
Time to create page: 0.076 seconds
