Please explain error measage
7 years 7 months ago #127993 by allenwg2005
Replied by allenwg2005 on topic Please explain error measage
I didn't know Vcarve would run on a Linux box, interesting.
I'm puzzled, G43 tool length off-set usually H(and tool number) calls the negative off-set for the tool height.
In what way is that added to the code I have generated?
G00 Z 0.501 is a retract value for clearing material and other stuff (clamps for example), it isn't loading a specific tool length.
I have my post writing the way I expected it to at the moment, I just need to clear up this G43 issue and I have it.
Thanks for all the help so far.
7 years 7 months ago #128007 by MaHa
Replied by MaHa on topic Please explain error measage
If you want to use toollength from tooltable, add a G43 as below. The Z values in the tooltable should be positive.
(I hope this is the right section, and check the output)
+ Commands output for Initial rapid move
"G00 G43 [X] [Y] [Z] [F]"
7 years 7 months ago #128013 by tommylight
Replied by tommylight on topic Please explain error measage
allenwg2005 wrote: I didn't know Vcarve would run on a Linux box, interesting.
I did try it some 5 years ago and it worked nicely . You just need to install vine before you try to install Vcarve.
sudo apt-get install vine
7 years 7 months ago #128014 by allenwg2005
This too gives me vales that move the tool, but I am still not loading the tool Z axis off-set.
My Fusion 360 ngc files have a ngc line that reads G43 Z0.xx H(tool number), it takes the offset value from the LinuxCNC Tool Table and offsets the tool given it's "Tool Touch Off" value.
Why isn't this Vetric post writing that code line?
My post has a call "G00 G43 [ZH]" in it, I must have something incorrectly written.
Thanks again
7 years 7 months ago #128016 by allenwg2005
Is that "vine" or Wine? (I haven't heard of vine but I don't know a lot of things).
I've never used Vcarve as a stand alone program, I bet you can't run Aspire in Wine, or with a beefy enough PC maybe you can..
7 years 7 months ago #128020 by tommylight
Do not bother with it, it is mainly used to do engravings from pictures.
Linuxc can run a lot of windoze stuff, it just might take a while to get them working in some cases.
Nothing can compensate for utterly useless and extremely bad coding done on some win software.
Time to create page: 0.161 seconds
