Please explain error measage
7 years 7 months ago - 7 years 7 months ago #127904 by MaHa
Replied by MaHa on topic Please explain error measage
I used Vcarve years ago for a short time. Didn`t like the results from .dxf files. Anyway, i did not find my old pp.
But as I remember, it has the ending .pp , and is actually a txt file. Easy be edited with Notepad++.
Use a copy of your pp for testing, and search for M6 , [TOOLNAME] . I think + is used to comment.
Or try and check the output:
"T[T] M6 [TOOLNAME]"
And found this on the Vectric Site
Start the program and use File > Open Application Data Folder. This will open a new window showing all the program's support folders.
Select the Postp folder to find the Post Processors.
Edit: I have seen the pp you got days ago, and found "T[T] M6( TOOL USE [TOOLNAME] )".
If you change it to "T[T] M6 [TOOLNAME] " and get rid off M600 near the header if you dont need it
Last edit: 7 years 7 months ago by MaHa. Reason: Found your pp
The following user(s) said Thank You: allenwg2005
7 years 7 months ago #127919 by allenwg2005
Replied by allenwg2005 on topic Please explain error measage
I'm not sure taking the time to inch through all this is any quicker than learning to code, and I'm taking a lot of everyone else's time as well.
Sorry about that.
New error:
"Multiple t words on one line".
No wonder with the following, I included a bit of the output in case there is another issue I haven't come to yet someone might see.
( Test ATC ) ( File created: Wednesday March 06 2019 - 01:58 PM)
( for LinuxCNC )
( Material Size) ( X= 12.000, Y= 10.000, Z= 0.750)
G91 (Incremental distance mode)
G17 G20 (Active Plane: XY)(Inch Mode)
G40 G49 G80(Tool Diameter, Length compensation & canned cycles off)
G64 P0.05 Q0.05(Path Blending)
(M600)
T1 M06 T1 End Mill (0.25 inch)
G90 (absolute distance mode)
G54 (Coordinate System)
S12000M5
G00 Z0.501
( T1 .250 EM 3D Roughing all )
G00 X11.077 Y9.348 Z0.500 F104.5
G01 Z-0.250 F40.0 M3 G4 P2
G01 X11.077 Y8.346 F52.3
G01 X11.077 Y8.329
I don't see a G43 H(?) in the code as well, in my other CAM output files that is in the script.
Any suggestions on how to overcome this one (I tried a number of guesses to no avail).
Thanks again in advance.
7 years 7 months ago #127920 by Leon82
Replied by Leon82 on topic Please explain error measage
you still have two comments on one line
put them on a new line and see if it works
7 years 7 months ago #127928 by allenwg2005
I'm just making a mess out of this situation.
I will attach what I have and maybe someone can explain what it is I'm doing wrong.
I was able to change to "Inches" (at lest I think I was, it hasn't loaded anything yet).
I have the post writing two lines now, one without comments. (I'll attach a copy of the gcode file as well).
I now get a message "Near line 12 Unknown word where unary operation could be".
Is unary even a word?
File Name: LinuxCNC_A...06-3.zip
File Size:2 KB
File Name: TestATC.zip
File Size:1,438 KB
7 years 7 months ago - 7 years 7 months ago #127929 by Leon82
(comments) (like this)
may be your problem
change them to
(comments)
(like this)
if it works without error, you know they are the problem
ETA, I tested it in a Sim. Double comments are ok
Last edit: 7 years 7 months ago by Leon82.
7 years 7 months ago #127931 by allenwg2005
I think I have the Tool call sorted (could be wrong about that not sure about anything I'm doing).
Still have the error "Unknown word where unary operation could be".
What in the world is it telling me?
Here's the post out put:
( Test ATC ) ( File created: Wednesday March 06 2019 - 05:02 PM)
( for LinuxCNC )
(M600)
S12000M5
G00 Z0.501
Time to create page: 4.645 seconds
