Beginner trying to learn basic programming
03 Jun 2019 04:32 #135692 by andypugh
Replied by andypugh on topic Beginner trying to learn basic programming
It looks like the sim config tops out at 2500, so that is pretty much what you will see with small diameter work and a high surface speed.
You can edit the config, though bear in mind that this limit might not exist in the HAL of a real machine.
Have a look in the HAL at the "limit_speed" pins and parameters. (Machine menu => Show HAL configuration)
(And note that, because of what it is, maxv = acceleration, and max = max velocity)
Time to create page: 0.184 seconds
