What sets the XY:UV separation distance in a GCode file?
- jeffgar2000@gmail.com
7 years 1 month ago #145907
by jeffgar2000@gmail.com
What sets the XY:UV separation distance in a GCode file? was created by jeffgar2000@gmail.com
I already run a XYZ laser cutter using LinuxCNC but now I am trying to set up a XY:UV foam cutter and I am generating GCode and trying to run it on LinuxCNC. Everything looks great and it runs my GCode files fine. I see my XY side and my UV side and it follows both. The only issue seems to be that the XY and UV sides are always 38.1mm separated on the screen even it they really should be separated by 100mm or even 1000mm .
I have been through the GCode and I see no "38.1"s so I have no idea where that is coming from.
My XY and UV towers are actually about 4' apart and many of the items I will be cutting are tapered so the spacing is critical in order to decide how big the patterns are run at the left and right side of the material.
The software I used to generate the GCode knows the tower spacing and the sizes of the left and right cuts plus how wide the material is (how far those cuts are apart.). Is it likely that although they show 38.1mm apart on the LinuxCNC screen, it already has baked in the correct angles?
For those that have ever run a foamcutter off linuxcnc, is there something in the GCode that needs to be set to display the spacing properly or is that just how LinuxCNC shows it? I'm completely OK with it if so but looking at the screen it just doesn't look quite right.
Jeff
Jeff
- Thank you received: 7491
7 years 1 month ago #145915
Replied by tommylight on topic What sets the XY:UV separation distance in a GCode file?
Remove any active offsets.
- pl7i92
- Thank you received: 358
7 years 1 month ago #145917
by pl7i92
Replied by pl7i92 on topic What sets the XY:UV separation distance in a GCode file?
(AXIS,XY_Z_POS,5)
(AXIS,UV_Z_POS,30)
this values sets the distances
(AXIS,UV_Z_POS,30)
7 years 1 month ago #146202
Replied by andypugh on topic What sets the XY:UV separation distance in a GCode file?
linuxcnc.org/docs/2.8/html/gui/axis.html...in_foam_cutting_mode
Put some "magic comments" in the G-code.
7 years 1 month ago #146209
Replied by jeffgar2000@gmail.com on topic What sets the XY:UV separation distance in a GCode file?
Not sure how I missed that but thank you for pointing that out. I will certainly test it tomorrow.
7 years 1 month ago #146211
I just went out to the shop and tried this. The XY_Z_POS in the foam.ngc was set to 5 and the UV_Z_POS was set to 40. That was close to the 38.1 that I saw on the axis display but not quite right. I tried changing each to various settings, saving and reloading the machine. It never changed the display. Seems like mine is ignoring the foam.ngc.
The first part of my ini is:
[DISPLAY]
FOAM = 1
GEOMETRY = XY : UV
OPEN_FILE = ./foam.ngc
DISPLAY = axis
and under the [TRAJ] section it has
AXES = 9
COORDINATES = X Y U V
[DISPLAY]
FOAM = 1
GEOMETRY = XY : UV
DISPLAY = axis
AXES = 9
Time to create page: 0.908 seconds
