What sets the XY:UV separation distance in a GCode file?
- Thank you received: 4654
26 Sep 2019 14:53 #146274
Replied by andypugh on topic What sets the XY:UV separation distance in a GCode file?
Maybe he means the sample .ngc file, which seems to be in the config folder, but not in the examle g-code folder.
github.com/LinuxCNC/linuxcnc/blob/master...m/axis/foam/foam.ngc
- dgarrett
- Thank you received: 297
26 Sep 2019 15:04 #146276
by dgarrett
Replied by dgarrett on topic What sets the XY:UV separation distance in a GCode file?
(2.8 branch):
foam.ngc is where it should be since the inifile
refers with relative (./) notation:
$ cd configs/sim/axis/foam
$ ls
axis_foam.ini
foam.ngcfoam.ngc is where it should be since the inifile
$ grep OPEN_FILE axis_foam.ini
OPEN_FILE = ./foam.ngcPlease Log in or Create an account to join the conversation.
- jeffgar2000@gmail.com
26 Sep 2019 16:11 #146278
by jeffgar2000@gmail.com
Replied by jeffgar2000@gmail.com on topic What sets the XY:UV separation distance in a GCode file?
Mine is version 2.7.14
I see the foam.ngc located at /linuxcnc/configs/sim.axis/foam.ngc.
The XY_Z_POS and UV_Z_POS was already in there but not responding to changes.
In a hurry, I hadn't noticed that the path to load that file was relative and set to "./foam.ngc". I copied it over to my machine config directory and it picked right up and now displays correctly.
It never threw an error saying that file wasn't available.
Problem is that it looks correct on the startup axis screen with those squarish things loaded. When I load one of my cut files it immediately goes back to the 38.1mm spacing.
I can restart LinuxCNC and it looks right again until I load my files.
26 Sep 2019 16:43 #146283
You need to put those comments in your cut files.
26 Sep 2019 16:47 #146284
I have:
(AXIS,XY_Z_POS,0)
(AXIS,UV_Z_POS,500)
At the beginning of my Gcode as well but it seems to make no difference.
When I load my Gcode (and it goes back to 38.1mm spacing), I see those lines listed along with the other GCode down in the code console under the axis display.
Is that the wrong syntax? I tried other forms and it ignored that as well.
(AXIS,XY_Z_POS,0)
(AXIS,UV_Z_POS,500)
26 Sep 2019 17:08 #146287
I copied the beginning of the foam.ngc into my cutfile and it worked.
I needed:
G17 G21 G90 G61 G54
(AXIS,XY_Z_POS,0)
(AXIS,UV_Z_POS,500)
(AXIS,GRID,5)
G0 x0 y0 u0 z0
I needed:
G17 G21 G90 G61 G54
(AXIS,XY_Z_POS,0)
(AXIS,UV_Z_POS,500)
(AXIS,GRID,5)
G0 x0 y0 u0 z0
Time to create page: 0.592 seconds
