- Thank you received: 358
What sets the XY:UV separation distance in a GCode file?
- pl7i92
7 years 1 month ago #146227
by pl7i92
Replied by pl7i92 on topic What sets the XY:UV separation distance in a GCode file?
unfortunaly someone has deletet the foam NGC
i added it here
i added it here
7 years 1 month ago #146248
Replied by andypugh on topic What sets the XY:UV separation distance in a GCode file?
I just tried the sample G-code, then edited the magic comments, and reloaded the .ngc and the display updated as expected.
Which version of LinuxCNC are you using? I tested with 2.8.
- pl7i92
7 years 1 month ago #146263
by pl7i92
Why has been the example removed from Master
it is needed for the SIM mashines
- dgarrett
- Thank you received: 297
7 years 1 month ago - 7 years 1 month ago #146272
by dgarrett
Replied by dgarrett on topic What sets the XY:UV separation distance in a GCode file?
2.7 branch: configs/sim/axis/axis_foam.ini
Ref: github.com/LinuxCNC/linuxcnc/blob/2.7/co...m/axis/axis_foam.ini
2.8 (and master branch): configs/sim/axis/foam/axis_foam.ini
Ref: github.com/LinuxCNC/linuxcnc/blob/2.8/co...s/foam/axis_foam.ini
Somethings may be relocated between major branches
Last edit: 7 years 1 month ago by dgarrett.
7 years 1 month ago #146274
Maybe he means the sample .ngc file, which seems to be in the config folder, but not in the examle g-code folder.
github.com/LinuxCNC/linuxcnc/blob/master...m/axis/foam/foam.ngc
- dgarrett
7 years 1 month ago #146276
by dgarrett
(2.8 branch):
foam.ngc is where it should be since the inifile
refers with relative (./) notation:
$ cd configs/sim/axis/foam
$ ls
axis_foam.ini
foam.ngc
$ grep OPEN_FILE axis_foam.ini
OPEN_FILE = ./foam.ngc
Time to create page: 0.556 seconds
