Strange behaviour M61 Qn and cuttercompensation
6 years 10 months ago #152310
Replied by andypugh on topic Strange behaviour M61 Qn and cuttercompensation
Sorry for the extreme delay.
I have determined that the error is raised by this line here:
github.com/LinuxCNC/linuxcnc/blob/master...terp_convert.cc#L856
And that, with your test file tool_radius at that point is 6.00mm
So, this implies that M61 does not update
settings->cutter_comp_radius
That, in turn, is set by the G40 handler here:
github.com/LinuxCNC/linuxcnc/blob/master...erp_convert.cc#L1944
Checking that data, with an M6 the radius is set to 1, with an M61 it is set to 6.
So my theory is that M61 does not copy the diameter data from the tool "pocket" to "pocket 0" (which is the spindle)
Unfortunately I have a plane to catch in 6 hours. There is some chance that I might get back to this during the week I am away.
The following user(s) said Thank You: MaHa
- MaHa
- Thank you received: 241
6 years 10 months ago #152462
by MaHa
Replied by MaHa on topic Strange behaviour M61 Qn and cuttercompensation
Thank you for investigating about this problem. Somehow i understand the description, but i am very far from being able to find a solution myself. As i completed this years work, I'm away for a while anyway.
- MaHa
6 years 9 months ago #154726
by MaHa
Now i circumvent this problem by Remap M6. The initial demand was, to be able to goto a freely selectable (manual)toolchange and probing position. I got this option, by removing toolchangeposition related entrys in the ini, adding variables for TCH and Z_OFFS, the standard toolchange and probing position. I have also the option in the .ngc file, to set this positions. If there is an entry in the .ngc, it overrides the .ini entry. At the same time, tool and z offset probing was improved. The first tool in the program sequence gets probed, then the toolsetter is placed on the workpiece, to get Z-offset, where a variable can be applied for minor corrections of the probing result. As we know, the toolpath doesn't match the preview anymore, after probing. So my probing routine has some funny testcounter, which allow to abort the program, ctrl-r, and when the program is started again, the 2 probing actions are skiped once, and the counter reset. A toolchange will reset this option also. This is only for the very beginning of a routine, with the first tool.
I did the testing in the simulation, also used the simulate_probe button, but still was tired of g38.n needing too much attention. A .ini entry 'SIM' with different values for the machine and simulation was made, to exclude certain programsequences in the simulation.
6 years 7 months ago #161115
I have looked at this some more, and I have noticed that if you ignore the warning, then the code runs properly.
It actually looks like the preview run-through is flagging an error, but there is no error at run-time.
You can see this in the simulator with your sample code (though the sim/axis-mm simulator needs the G53 move to be made a bit shorter)
M61Q2 = error box but runs OK
M6 T2 = all OK
M61 G12 = error box _and_ run-time message and program stop.
Running the tklinuxcnc simulator (no preview) has both versions of the code working. (but errors with M61Q12, as it should).
So this really does seem to be a problem with G-code preview rather than with the actual program execution.
M6 T2 = all OK
Time to create page: 0.516 seconds
