- Thank you received: 994
G code Generators
- BigJohnT
5 years 4 months ago - 5 years 4 months ago #211799
by BigJohnT
Replied by BigJohnT on topic G code Generators
I added drilling speed and feed calculators. In the past my speed and feed calculators while correct were clunky and required typing in numbers. I wanted to change that and make an easier way to get rpm and feed for drilling ops. So this one you select units and material and adjust the sliders for SFM or SMM you want and IPR (still need to fix MPR) offset for feed and lastly you can pick the depth of the hole times the diameter for a reduction in speed and feed for deeper holes. I'm not really sure how to offset the feed per rev on metric, for imperial it's 0.001" per 1/16" +- 0.001" on the total.
JT
JT
Last edit: 5 years 4 months ago by BigJohnT.
- BigJohnT
5 years 4 months ago #212324
by BigJohnT
The following user(s) said Thank You: tommylight, Clive S
Time to create page: 0.283 seconds
