G code Generators
5 years 5 months ago #210792 by BigJohnT
Replied by BigJohnT on topic G code Generators
You can save the settings now and I've fixed the precision to 4 places.
JT
5 years 5 months ago #210798 by BigJohnT
What type of path should a pocket routine use? Just G1 or an arc in the corners?
JT
  • Moderator
  • Moderator
5 years 5 months ago #210806 by tommylight
Replied by tommylight on topic G code Generators
It works ! :)
Also tested on a sim, everything looks good, might need more testing.
The following user(s) said Thank You: BigJohnT
5 years 4 months ago #211153 by BigJohnT
Finally making progress on the pocket routine.
JT
5 years 4 months ago #211320 by BigJohnT
Getting closer on a proper path for a pocket, just need to add the Z depth steps and I think it's done. Notice how each pass the cutter stays engaged with the material for the same woc vs a G1 path the cutter will rub in the corner and wear out faster.
JT
5 years 4 months ago - 5 years 4 months ago #211418 by BigJohnT
AFAIK the pocket routine is finished and working. Testing would be nice.
The path is rapid to safe z then rapid to the start point then feed down to the top of the material and then ramp down to the first z depth then keeping the cutter fully engaged in the material by using arcs on the corners cut the pocket. As the cutter gets to the point where larger arcs are needed to finish up the pocket the arcs start to increase.
While testing I also put the finished pocket path so I can see that the pocket is cut properly and that's why you see the outer path.
JT
Last edit: 5 years 4 months ago by BigJohnT.
The following user(s) said Thank You: tommylight, itsme
Time to create page: 0.273 seconds
