- Thank you received: 2177
[REMAP FOR M6] Why does linuxcnc run the .ngc file on startup?
5 years 2 months ago - 5 years 2 months ago #219013
Replied by Aciera on topic [REMAP FOR M6] Why does linuxcnc run the .ngc file on startup?
Ok, I can confirm on a simulation config that the code in a M6 ngc remap is executed at start up.
[edit] Just learned something. Thanks bevins.
o<tool_change > sub
o100 if [#<_task> GT 0]
; code here
o100 endif
o<tool_change> endsub
m2
o<tool_change > sub
; code here
o100 endif
m2
Last edit: 5 years 2 months ago by Aciera.
The following user(s) said Thank You: bevins, ehb
- mugurlu
5 years 2 months ago #219014
by mugurlu
Replied by mugurlu on topic [REMAP FOR M6] Why does linuxcnc run the .ngc file on startup?
this is how it works, we now prevent it from running directly on boot
thank you bevins
thank you bevins
o<tool_change> sub
O300 if [#<_task> EQ 0]
O300 else
(print, rack_change: loaded tool=#<_current_tool> current pocket: #<_current_pocket>)
(print, rack_change: selected tool=#<_selected_tool> selected pocket: #<_selected_pocket>)
M68 E0 Q#<_selected_tool> ;Set target tool number
M64 P0 ;Enable tool changer
G4 P0.5
M66 P0 L3 Q10; wait for carousel-locked = false
o202 if [#5399 EQ 0]
M65 P0 ;Disable tool changer
(abort, carousel still locked hello)
o202 endif
G43 H#<_selected_tool>
(print,mcode end)
O300 endif
o<tool_change> endsub [1]
M2
- bevins
- Thank you received: 338
5 years 2 months ago #219020
by bevins
Replied by bevins on topic [REMAP FOR M6] Why does linuxcnc run the .ngc file on startup?
I really need to challenge my fear of an ngc remap and just do one....
Time to create page: 0.145 seconds
