G43.1 Dynamic Tool Length Measurement - Program Exceeds machine maximum on axis
4 years 11 months ago - 4 years 11 months ago #226589 by +Jan+
I have a small problem with dynamic tool length measurement with G43.1.
I call via remap a macro on this basis:
My adapted macro looks like this
o<messen_eng> sub M64P10 #1700=1200            (Tool change X position) #1701=0        (Tool change Y position) #1702=-1        (Tool change Z position) #1800=-100        (Position safe Z/Starting point for G38.2 move) #1801=1279.125         (position probe X) #1802=2498        (position probe Y) #1900=#<_coord_system>    (Store coordinate system only G54 till G59) o500 if [#<_current_tool> EQ #<_selected_tool>] ;(debug, Tool already in spindle) o500 else  M5 G54 G90 G0      G53 Z#1702            (Go to tool change Z position) G53 X#1700 Y#1701        (Go to tool change XY position) M6 T#<_selected_tool> #4999=#5400. (save actually loaded tool... for another macro) G43.1 Z0            (TLO reset) G53 X#1801 Y#1802       (Go to probe position) G53 Z#1800            (Go to save Z position) G91 G38.2 Z-197.5  F850        (probing fast) G1    Z2.0  F150        (go up a bit)     G38.2 Z-2.25  F25         (probing slow) #2000=[#5063+#5223]     (Switching point+zero Offset) #2001=[#2000-#2002+#2003](new - diff + old)   #2002=[#2000]           (Save old switch point) #2003=[#2001]            (Save old offset)      G1 Z5.0 F500            (go up away from sensor) G90 G0 G43.1 Z#2001            (TLO set) G53 Z#1800         (Go to save Z position) G53 Z#1702            (Go to tool change Z position) #1803=1            (State tool already measured) ;(debug, Differenz ist: #2001) (Restore old zero (only G54 to G59)     o100 if[#1900 EQ 540] G54 o100 endif o101 if[#1900 EQ 550] G55 o101 endif o102 if[#1900 EQ 560] G56 o102 endif o103 if[#1900 EQ 570] G57 o103 endif o104 if[#1900 EQ 580] G58 o104 endif o500 endif M65P10 o<messen_eng> endsub M2
My Z axis has the following specification
[AXIS_Z]
MAX_VELOCITY = 100.0
MAX_ACCELERATION = 700.0
MIN_LIMIT = -300.0
MAX_LIMIT = 0.01
My workflow is as follows.
1. tool measurement via the macro above
2. define Z0 (for the tests I set it far away from machine limits)
3. start program
If I now start a program I get the message, "Program Exceeds machine maximum on axis Z.". As far as I could understand, the error occurs when the machine is moved to different Z heights in the program run.
For example, this code works here:
G21 (Units: Metric)
G40 G90
F1
M6 T9 ( Cutter, 6 mm)
G0 Z10
G0 X0 Y0
G01 Z10 F2000 (same height)
G01 X20 Y20
G01 X0 Y0
G0 Z10
M05 M30
This one as well:
G21 (Units: Metric)
G40 G90
F1
M6 T9 (Cutter, 6 mm)
G0 Z0
G0 X0 Y0
G01 Z0 F2000 (same height)
G01 X20 Y20
G01 X0 Y0
G0 Z0
M05 M30
This however not only with the above mentioned error message:
G21 (Units: Metric)
G40 G90
F1
G0 Z0
G0 X0 Y0
G01 Z10 F2000 (different height)
G01 X20 Y20
G01 X0 Y0
G0 Z0
M05 M30
If I then click on "Run anyway", the program runs through to the end of the cycle without any problems. However, since I have to click the message away every time and thus cannot use my external hardware start button, I would like to solve the problem. Does anyone have a troubleshooting approach?
Best wishes
Jan
Last edit: 4 years 11 months ago by +Jan+.
4 years 11 months ago - 4 years 11 months ago #226670 by andypugh
I think that the problem here might be that probing always fails in the preview.
Judicious use of
O100 IF [#<_task> EQ 0] simulate probe O100 ELSE actually probe O100 ENDIF
Might fix the problem.
Last edit: 4 years 11 months ago by andypugh.
4 years 11 months ago - 4 years 11 months ago #226736 by +Jan+
I'm afraid that I'm not judicious enough to implement that accordingly ;-).
Can you please describe the workaround in more detail?
Thanks in advance
Jan
4 years 11 months ago #226737 by andypugh
It's hard to know without context.
One thing to look at... What does your code do if the probe fails to find the sensor?
4 years 11 months ago #226739 by andypugh
Looking at the preview interpreter:
github.com/LinuxCNC/linuxcnc/blob/master...sai/saicanon.cc#L397
It looks like the tool point moves to 0.254mm short of the programmed probe end position, but does not set the "probe success" parameter flag.
The issue that you are seeing is likely to be that the calculated result in preview mode appears to be a very short tool, one with a tip somewhere inside the headstock.
Maybe just skip the whole probe routine if #<_task> EQ 0 ?
4 years 11 months ago #226740 by andypugh
The following user(s) said Thank You: +Jan+
Time to create page: 0.256 seconds
