G76 problem
3 years 10 months ago #259784
Replied by andypugh on topic G76 problem
Do you have a circuit diagram for the stepper drive control pins?
- Ismacr63
- Thank you received: 11
3 years 10 months ago #259786
by Ismacr63
I used this diagram that I found on the net.
Replied by Ismacr63 on topic G76 problem
3 years 10 months ago #259788
That's the BoB, not the stepper drive.
- Ismacr63
3 years 10 months ago #259789
by Ismacr63
are you referring to this?
stepper drive.
3 years 10 months ago #259790
Yes. That indicates that the drives use differential inputs, so as long as you have 7i76 step + to drive step + (and so on) then it isn't a step polarity issue.
- JPL
- Thank you received: 118
3 years 10 months ago #259801
by JPL
Replied by JPL on topic G76 problem
I've found another manual for the T60 drive here:
www.rtelligent.net/upload/wenjian/Steppe...%20User%20Manual.pdf
I think you should have a look at sect 4.5 related to SW8.
In your manual it is for the bandwidth selection but in the manual linked above it is for Open/Closed loop selection, According to the pdf manual (above) SW8 should be set to 'off' for closed loop mode.
This is quite strange since just about everything else is identical in both manuals.
Time to create page: 0.144 seconds
