G code is not working...
- Thank you received: 4646
I have been fiddling round in Excel, and EMC2 is not wrong, those numbers really don't work.
- axel88
- Thank you received: 3
If this shouldn't work, I found an option that should solve all these problems:
Output Circular Record
You can set this option to Yes or No. If set to Yes, the system outputs all circles based on the circle motion parameters. If set to No the system does not output circle blocks (G2 or G3).
But I think it's quite better to use circles based parameters if this is possible, right?
- axel88
But with Output Circular Record disabled it worked. So is it a handicap without G2 G3 or is it equal?
In the Attachment is the working postprocessor without Circular Outputs.
Attachment EMC2.zip not found
Ok even in Metric and Minimum Resolution =.0001 the error remains.
You might need to also change the number of digits of numbers that get output
As an alternative, you can probably do circular moves in X Y Z R mode, then it is EMC2's job to make the radius work.
Files will be much bigger, and will probably run a lot more slowly as the motion planner has a harder time.So is it a handicap without G2 G3 or is it equal?
- axel88
Secondly I don't understand why i should make the values much more precise than my mill could handle?
So do you think the error will be solved if I set the Cordinate Format to 5.4?
The X,Y,Z format is set as "Cordinate" "5.3" -> XXXXX,XXX but in my *.ngc there are for e.g. "N0110 X-2.6228 Y2.5496" so one position after decimal point more than specified. Thats some kind of strange
The whole thing is rather strange.
The problem is that the postprocessor is outputting nonsense. If you look at those start-centre-end coordinates they do not define a circle, the centre is nearer one end than the other. EMC2 can't work out what to do about that. I have no idea how it is possible for the postprocessor to get it wrong, but it is doing.
I would be tempted to set it to 5.8 and the accuracy to 0.00000001 just to see what happens.
Is this an official, paid-for installation of Unigraphics? I think this should be a support call / bug report.
- axel88
Thanks a lot!
It will be a bigger file than with the lower precision, but only the same number of moves.
Unless the settings are wrong in some way, and G2 and G3 are not in the new file either. Have you looked?
You should be able to ratchet back the resolution and precision to a point that works but is less silly.
- axel88
I think I'll cope without Circular Moves. This works fine.
