M codes
20 Jun 2011 13:01 #10651 by BigJohnT
Replied by BigJohnT on topic Re:M codes
You get the "unknown m code" error for any kind of error with M1nn.
20 Jun 2011 13:02 #10652 by piasdom
Replied by piasdom on topic Re:M codes
ok.
20 Jun 2011 16:23 #10671 by ArcEye
Replied by ArcEye on topic Re:M codes
Hi
EMC normally internally converts just about everything to lowercase and you can't have capitalised sub file names for instance because of this.
Linux sees M101 and m101 as completely different files
If you name your file m101 but type in M101 at the MDI prompt, you will get the 'unknown M Code' error
If however you name your file M101, you can execute it with both M101 and m101 at the MDI prompt.
Why exactly the second one works I don't know, but it does, I have just done it!
20 Jun 2011 17:11 #10672 by piasdom
Thanks ArcEye , but all are small lettering.
back to the net.
20 Jun 2011 17:27 #10673 by BigJohnT
piasdom wrote:
working on Mnnn
i have the file m101 in my PROGRAM_PREFIX directory and it's executable.
i'm trying to call it in my program with m101 p4. i'm getting "unknown m code used"
T'anks !
my m101 file;
#!/bin/sh
feedrate=$2
halcmd setp thc.feedrate $feedrate
exit 0
Do you have a plasma torch now?
Did you load the thc component?
20 Jun 2011 19:08 - 20 Jun 2011 19:09 #10677 by piasdom
does the m1nn file have a file type to be executed ?
m110.???
Last edit: 20 Jun 2011 19:09 by piasdom.
20 Jun 2011 19:17 #10679 by BigJohnT
Nope, what are you doing with the torch height control component?
20 Jun 2011 19:40 - 20 Jun 2011 19:54 #10680 by piasdom
BigJohnT wrote:
piasdom wrote:
working on Mnnn
T'anks !
my m101 file;
#!/bin/sh
feedrate=$2
exit 0
that must be it. no torch :)
and don't know anything about thc.
was trying to get a feed variable
saw it in the doc and thought it was something else
thanks anyway.
Last edit: 20 Jun 2011 19:54 by piasdom.
20 Jun 2011 20:44 #10682 by BigJohnT
It shows your doing some looking around in the docs :)
2.5 has pins to set the feed rate with a value...
20 Jun 2011 21:35 #10685 by piasdom
Thanks John, i'll have to wait.
Time to create page: 0.184 seconds
