Newbie, How to touch off Z axis
- macruzq
06 Aug 2011 18:42 #12252
by macruzq
Replied by macruzq on topic Re:Newbie, How to touch off Z axis
I am using the default configurations, set by last build of system.
- macruzq
06 Aug 2011 18:43 #12253
by macruzq
Yes, I homed all axis first, before moving Z axis.
- Thank you received: 4995
06 Aug 2011 18:47 #12255
Replied by andypugh on topic Re:Newbie, How to touch off Z axis
macruzq wrote:
Which cnc machine configuration are you using?
What does it say in the window title bar of EMC2?
I think you are misunderstanding my question.I am using the default configurations, set by last build of system.
- macruzq
17 Aug 2011 16:18 #12545
by macruzq
Sorry for the delayed reply.
I am using "axis.ngc"
OK, I pressed "$" and axis were changed to X Y Z, then I coud click on "Touch off"; window opens asking for a value: which value should I type in?
- BigJohnT
- Thank you received: 1176
17 Aug 2011 16:22 #12546
by BigJohnT
Replied by BigJohnT on topic Re:Newbie, How to touch off Z axis
What ever you want the present position of the currently selected axis to be... also depends on if you have a tool loaded or not and if your touching off a coordinate system or the tool table.
What do you want to do?
- macruzq
17 Aug 2011 16:39 #12547
by macruzq
I only want to run axis interface the same way I did with 2.3.5: just build the system, I ran it selecting 5axis form the initial menu ant click on run. That's it.
Why is this not possible with 2.4.6?
- BigJohnT
17 Aug 2011 16:41 #12548
by BigJohnT
Run what file?
17 Aug 2011 16:59 #12549
macruzq wrote:
The complex kinematics need to home in "joint mode" before they can switch to coordinated mode.
If you don't need 5-axis machining capability then you can use a simple trivial-kinematics configuration which will start up automatically in XYZ mode.
Have a look at www.youtube.com/ChrisRadek#p/u/10/7WCrqqoZkPg for an example of what is meant by "5 axis" in this context.
Because the 5-axis example is not just a simple X, Y, Z A, B configuration, but rather a complex 5-axis kinematics example where the work position and head angles are automatically computed to set the required tool positions and angles relative to the work.I ran it selecting 5axis form the initial menu ant click on run.
Time to create page: 0.064 seconds
