Changing the openGL colors in the Axis GUI
6 years 6 months ago #163112 by tommylight
It works. It also changes the colours, only once, and upon relaunch it sets the colours back to default.
6 years 6 months ago - 3 years 1 month ago #164178 by zack
Herewith fix
Last edit: 3 years 1 month ago by zack.
6 years 6 months ago #164182 by tommylight
The following user(s) said Thank You: zack
6 years 6 months ago #164187 by FariaAl
It works for me, restarted linuxcnc a few times and color scheme remains.
using linuxcnc 2.8 latest
6 years 6 months ago - 6 years 6 months ago #164234 by phillc54
I have updated the test branch with your latest version
forum.linuxcnc.org/21-axis/16426-changin...-gui?start=90#162637
Colour changes worked and stayed for the next run.
What is the purpose of the ticker?
I really don't like the X in the bottom corner, it is a bit unexpected (for me) to have an exit there. If you insist on having it then you should at least create a tooltip for it and maybe give it a warning colour like the ESTOP on the left. Actually I think you should get rid of it as there are already enough ways to exit.
Last edit: 6 years 6 months ago by phillc54.
6 years 6 months ago - 6 years 6 months ago #164235 by zack
On my touchscreen the exit button is a bit small on the top right so I have it bottom right.
With no Keyboard and mouse around input cntr-q/Q is not an option.
If you have another suggestion i will revise the position or solution.
maybe exit word instead?
Any other suggestions or revisions more than welcome, the numerous installs I have done with axis,
namely on gantry routers, users seem to request a return home and larger buttons.
Most generate g-code with a post processor so do not frequently read the g-code, hence the option Cntr-h
to hide the code pane. Cntr-g to show it again.
How many users have touchscreens, I wonder? It might be plausible to add a pop up input panel with a revised
keyboard for the MDI pane, any thoughts. Should it double as a touchy type interface as well?
Last edit: 6 years 6 months ago by zack.
Time to create page: 0.073 seconds
