How do I do a manual tool change?
- ArcEye
- Thank you received: 240
The component I attached worked fine when I tested it.
Also start linuxcnc from a terminal and post the output, the error you cite is generic, hopefully the other output will give the full story
- LS
Please see the attached zip. I also started LinuxCNC from the terminal for you to see the error.
I had to press CTRL-C (^C), otherwise it will wait continously. I have tried waiting, but it never gets past waiting for the script to start.
Cheers,
Luke
linuxcnc@linuxcnc-desktop:~$ linuxcnc /home/linuxcnc/linuxcnc/configs/LS/LS.ini
LINUXCNC - 2.5.3
Machine configuration directory is '/home/linuxcnc/linuxcnc/configs/LS'
Machine configuration file is 'LS.ini'
Starting LinuxCNC...
Waiting for component 'hal_manualtoolchange_jog' to become ready.............................................................................................................................................................................................................................................................................................................................................................^C.
LS.hal:88: hal_manualtoolchange_jog exited without becoming ready
Cleanup donePlease Log in or Create an account to join the conversation.
- ArcEye
I will be able to test your config later, but I suspect I have found the problem.
# loadusr -W hal_manualtoolchange
loadusr -W hal_manualtoolchange_jog
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
You have renamed the component file to hal_manualtoolchange_jog
Unless you have edited the component code to rename the component to the same name,
it will launch the component which is still called hal_manualtoolchange and wait for ever for a component called hal_manualtoolchange_jog to become ready, which it never will.
Then it would error anyway because iocontrol is still linked to hal_manualtoolchange
Revert to the original name and it should work
- ArcEye
- LS
I'd spent plenty of time looking at the code, but never would have thought about the filename.
This will make life easier to be able to jog during manual tool changes.
Cheers,
Luke
- eslavko
Till now I use the old branded machine. (EMC2 - it's works so I didn't change)
But now I make another one for a friend. And component doesn't work as should.
When M6 is executed the popup window is shown. And I happily change tool and make Z touchoff.
When I press continue tha machine start immediatly with spindle OFF!
So how to add spindle on and to wait spindle-at-speed signal (my spindle make slow ramping to reach speed)
Of course I can start spindle manualy after changing and wait enought to startup before click continue..
...but preffer automatic!.
- ArcEye
I just do it in G Code if I want the spindle stopped and re-started
M5
G28
M6T2
M3
G4 P10
There are so many different types of toolchanger, with a lot not wanting the spindle stopped (almost all lathes), coding it is probably easiest
- eslavko
M5
G28
M6T2
M3
G4 P10
Maybe this is good option as in most cases when tool is changed the spindle speed is changed too.
- robksawyer
- Thank you received: 4648
Can you describe exactly what problems you are having?
